Monoprice Monolith 10” THX Select and 12” THX Ultra Subwoofers Review
  • Thread starter Thread starter gene
Its for $675 because through the 29th there is a $125 off $500 monoprice coupon code that this works on.
  • Like
Reactions: 1BADAPPLE
I'm considering getting dual Monolith 10s vs a single PB-2000 Pro. With the Monoliths I'm concerned about the relatively high distortion through the midbass (is it audible?) and the relatively low peak midbass output. With the SVS I'm concerned about the high group delay and missing out on dual subs. Basement cave is 12x20x7 and I usually find reference level far too loud so am thinking with the dual monoliths I'll rarely push into the high distortion zone. Thoughts? Other options?
Your concerns about group delay and distortion are unwarranted. Neither are at levels that are audible. Between those two choices, I would go for the Monolith subs because multiple subs can yield a flatter response which means better sound quality - but only if you take the time to set them up correctly.
James @shadyJ
What do you think about dual SVS PB-2000pros vs dual Monolith 12s? I currently own the two PB-2000s pros and i was wondering about the monolith instead. I'm not concerned about the app with the SVS, since i set it once and forget it. I have a custom wall opening and cant fit anything much bigger
Thanks!
James @shadyJ
Thanks!
Without looking at the measurements, just what would you expect to gain by that switch particularly? Do you have other uses for the SVS subs and just want to experiment?
IMHO "Horizontal change", meaning changing to something similar in performance may be waste of money. If I change something, it would be to getting a product significantly better :cool:
James @shadyJ
Thanks!
The 2000Pros are pretty darn good. I don't think you would gain much, maybe a bit more power at the low end. The Monolith 12"s are also larger and MUCH heavier.
  • Like
Reactions: haraldo and tn001d
Whats the basic Monolith 12" settings people are starting at on the sub itself
Old thread bump...the Monoprice 12" THX Ultra is currently on sale for $570. Thats a lot of sub for a really good price, slightly lower than value champ Hsu VTF-2 Mk 5 in this 12" sub category.
linky
That is a terrific deal for that sub. Crazy good bargain! Any other manufacturer would price something with that performance and build quality at double that cost!
  • Like
Reactions: lovinthehd
It's a bargain. They still have, as yet, unresolved issues with amp reliability.
But you'll not get a sub, better, cheaper.
The amps though, caveat emptor.
I am not sure how much worse their failure rate is versus the norm, but what I think makes it more of an issue is that it's more cumbersome to deal with the issue since they want customers to send the entire unit back, and those are very heavy subs. It's the kind of service you would expect from a large corporation rather than the more personable service you get from a small business. The good news is that Monoprice does honor their warranties without giving customers flack.
Iirc, they have started sending amps out to customers like svs does. Haven’t followed closely, but seems like I saw that.
  • Agree
From experience of all available sources, owners forums and such, the amp failures are above normal rates. I've had a fail rate of two from two within warranty, That said, I got mine at about 50% off, they refunded one and sent a replacement replaced the other, leaving me with two dead subs and a brand new one.
There was no way to return the dead subs, so I'm going to revive the two failed subs with an external amp.
I've no issues with Monoprice CS, other than they are a big company and subs aren't their bread and butter business, so they don't know what a faff it is to deal with 60+KG subs and the logistics of returns.
Even with the knowledge of possible amp issues, 59% off an already OK retail price is really tempting.
I've invested in an external amp to power my two dead m-15 subs.
Replacement amps weren't an option for me, and the talk of them sending replacement amps for failed ones has been off and on. There's no consistency in their resolution. Nor a solution to the reason for failure, The dreaded 'Christmas Light' red/green protection mode trip.
Great sale, but worth noting
The US version appears to be listed as not on sale, but priced at $899.99
  • Like
Reactions: everettT
That makes
D'oh! Good catch.
That makes no sense. They are selling a UK/EU 240v unit at 59% discount, whilst also specifying no international orders taken?
What's their market, people with transformers?
