Monoprice Monolith 16” THX Ultra Subwoofer Performance Analysis
  • Thread starter Thread starter shadyJ
shadyJ
Speaker of the House
Staff member
Oct 16, 2006
12,053
0
113
Monoprice knocked us out of our socks in our review of their new Monolith 13” THX sub, and we were very intrigued by its bigger brother, the 16” THX Ultra. Unfortunately, the 16” was just too large and heavy for us to do a full review (hey, you try lugging a 170 lbs subwoofer up and down a steep flight of stairs multiple times!) Happily, Monoprice was able to coordinate a sample for testing, so we can get a close look at its performance even if we aren’t able to do any listening in our home. The results of our testing are the subject of this performance analysis. Read our full performance report of the Monoprice Monolith 16" THX Ultra...
READ: Monoprice Monolith 16" THX Ultra Subwoofer Performance Analysis
Dear Monoprice,
Please make subs with a satin black and/or gloss black finish.
Thanks,
UBG
Ohhhhhhhh I've been waiting for this one. Look at the performance
Output? Check
Extension both infrasonic and midbass? Check
Extremely low distortion and great measurements? Check
Does it outperform the SVS PB16 ultra for a lot less money? Hell yeah Check Check Check
It seriously outperforms the SVS
I hear they are coming out with a piano black gloss next year. By that time plenty of user reviews If everything sounds good from users then 2 of them are going in my room
Krikey, mate! Now THAT, is a Subwoofer.
If it wasn't potentially so confusing, it should be referred to hereafter as "The Übersub." :)
(Suck it, Nietzsche.)
Shady, did you do these measurements yourself up in Chi-Town? Just not getting it into your pad for a listen? ;)
Output? Check
What, nothing about the ports, 'Zilla?
8! Count 'em...
That's one for every night of the week, and twice on Sunday! :p (Since I know you won't give one a week off!)
<3
I did the measurements, but not anywhere near an urban area. I did have help. In its boxed state, I doubt that I could even fit it through my door. I can't personally use it to its potential, so I didn't want to bother with the pain of lifting it into my theater room which involves a flight of stairs.
Totally dig it. And I know I speak for everybody when I say:
Thank You for measuring this beast!
8! Count 'em...
<3
I'll have you know Ryan the ports had NOTHING to do with how I feel about this subwoofer. AT ALL :rolleyes: ;)
  • Like
Reactions: panteragstk
If your ever in San Antonio someday post pandemic PM me. For all the work you do your gonna get treated bro. For reals.
“The Monolith 16” can produce more than 50% more output than the Monolith 13” while only having a 25% cost increase.”
This is nuts.
This is nuts.
I know I was thinking the same thing
This is nuts.
Percentages just aren't the way to deal with logarithmic specs....
Legit question. Is there a point where, depending on what level or gain we leverage that some won't realize the upside from say the 13 vs the 16, especially if you already have multiple quality subs?
It's probably the wrong audience to ask this question :)
I'd think would depend how many you have and in what size room and to what levels you're driving them....but for most it's probably moot.
  • Agree
Well this is kindof the point @lovinthehd is making above. Higher output and numbers don't always tell the whole story
in certain room sizes or use situations you may not need that extra output at all.
You definetly have to take all factors into consideration before you cough up the extra dough
  • Like
Reactions: Kleinst
So I should infer that loudness will be less than half (n00b here)?
Depends on what you mean. 3dB in spl requires a doubling of power....and distance comes into play as well. Percentages just aren't the right mathematical ways of expressing differences
ps Also consider that generally that perceiving a loudness difference of double is in the range of 6-10 dB spl difference depending whose definition you're using.
  • Like
Reactions: tinman143
