If you do that the sub will be highly bass deficient, as the sealed sub requires a 12 db. per octave boost below F3, and a sharp cut off at the point the driver exceeds x-max. Ported subs do not require that bass boost, and actually would be harmed by it. So the answer is that your plan will not work.
