Numerous questions on my setup, Bipole vs Monopole for distance, sub placement, 2 ch amp for Ultra Towers
the machine
the machine
Hello All,
I have a few questions regarding my setup. I have a somewhat accurate depiction of the room. Speaker size is accurate. The bottom right corner is a built in bookshelf that needed to be added because behind this area is ductwork and a water heater. At around 9 feet from the TV, there is a structural beam that runs across the ceiling. We enclosed other ductwork on the ceiling toward the front at the same height, basically is made a rectangle on the ceiling that is 16" in down from the ceiling and runs the entire length of the ceiling from the 9 foot mark to the TV wall. It's about 11 inches wide, but totally open in the middle (ceiling is back to 8ft). Along this area my Atmos speakers are mounted. Because of this the MLP will be roughly 6.5-7 feet from the front wall, I think the back of the couch should sit around the 9ft mark in the room. All of the boxes that represent the speakers are to proportion: SVS Ultra towers and center (not shown as it just sits on top of the TV stand) in the front, along with 2 PB 2000, 4 Prime elevations, 2 Ultra bookshelves behind sofa. The room is roughly 16x20x8, not accounting for the built out area in the lower right hand portion of the picture. Nothing is set up as of yet except the Prime elevations. The room is in the last leg of construction, the floor (carpet)
I'm wondering given the 10ft plus distance from the MLP, would a monopole speaker be more beneficial vs a dipole? I know people have their preferences, but my main concern is the distance and if one might perform better than the other. The photo below has the Dipole to size shown in the back of the room.
I have already wired everything in wall so there's no changing at this point (plus the bottom left corner of the photo will likely have a small bar or something in it, so opposing sub placement isn't an option) but would it be more beneficial to have the subs on the inside or outside of the tower placement? If inside, the towers can be angled more, but then the subs may be too close to the MLP and possibly overpower. I'm not quite sure if a few feet in this case will make that much of a difference.
Lastly, the amp I have is a Marantz 7012, 9.2. I currently have 9 channels, so if I add rear surrounds (which I'm wired for), what is a good 2 channel amp that would work well with the Ultra Towers? I wouldn't be opposed to selling the 7012 and stepping up to an 11.2 if it makes more sense.
Thanks in advance for all your suggestions.
shadyJ
Speaker of the House
Staff member
I would absolutely go for bookshelf speakers for the surrounds in that situation.
I think that the SVS Ultra towers should be OK with that AVR. SVS specs them at 8 ohms. It certainly wouldn't hurt to put them on a outboard amp. The less strain you can take of the AVR the better. I would look at getting a three channel outboard amp for the left, right, and center. Look at Outlaw Audio or Monoprice Monolith for a good amp for that.
the machine
the machine
Awesome, thanks for the suggestions. Just out of curiousity, why bookshelves in this situation? Is it the distance? Is it the direction of the woofers on the surrounds? I’m guessing going with prime satellites would be much more beneficial as the ultras aren’t going to be that much better for ambient noise. Does that sound reasonable or am I leaving something on the table.
I have an in at an audio store and can probably get a discounted parasound or emotiva. Any reason to go with outlaw or mono price vs parasound or emotiva? I prob should note that this is for 80% movies and 15% music, 5% gaming.
shadyJ
Staff member
I agree there is not a reason to spend big on rear surrounds. Prime bookshelf speakers should be sufficient for that role.
As for Outlaw and Monoprice Monolith vs Emotiva and Parasound, I think the Parasound is likely to be quiet a bit more expensive without a real increase in performance. I don't really trust the reliability of Emotiva. However if you can get three channels of amplification wattage from a Parasound for the same price as a Outlaw or Monolith, sure, go for it.
the machine
the machine
Thanks shady, I swear you’ve commented on almost every post I’ve made and I really appreciate it. Will check out what my price will be on an a31, probably 1800 if I had to guess. Might be worth it to save the $$$ and check out outlaw and monoprice. I’ll weigh all the options.
the machine
the machine
Also, to give a better visual, see photos below. Yes it’s still a mess with tools and such. First two photos show the drop down from the ceiling, and why it needs to be close to the tv area so the rear atmos are slightly behind the sofa. Third photo shows depth of built in, and 4th shows the position of the rear surrounds and how close the right rear (left of photo) is to the built in.
Danzilla31
Very nice bipole s or dipole speakers are only used know when the listener is very close to the speaker and you want to avoid beaming to that person at that spot
But in your space with your setup and the distance you have monopoles work much better
The issue is imaging and panning of sounds as they move across the room the way the sound engineer intended
Monopoles are excellent at this and this is what you need in an atmos object based type of surround system
Bipoles and dipoles were great for channel based 5.1 or 7.1 systems back in the day but not for the new systems that are object based formats like DTS Nueral X and atmos or auto 3D
The reason is again monopoles are better at pinpoint imaging and panning where bipole s and dipoles are better at just spreading the sound around you
Trust me I've been there in my theater room we went from bipoles to monopoles and it made a huge difference night and day for atmos based types of soundtracks heck just quality sound period
The room with bipoles
The room with all monopoles
The difference with all monopole speakers for dts neural X and atmos content hell even for upmixing is just night and day over bipole s it's not even close
With all monopole JBL studio 5 speakers for my base 7 I get that feeling with the sound where I get a natural high of off listening to movies and music never happened with the bipoles
You have the space to do it right with monopole speakers in my opinion I say go for it
the machine
the machine
Update:
So the parasound is a no go, legacy model is on closeout and can't go lower at 2700. So I have decided I will go with either the Monoprice 5 channel (3 is sold out, plus its only 200$ more for 2 more channels so why not) or 3 outlaw 2200. The 3 outlaws are $500 cheaper. I've read a few threads on both but am undecided on which would be the best option.
Thanks again for your thoughts
ryanosaur
ryanosaur
2200 just reviewed by Amir over at ASR (fwiw).
I use 5 in my rig for Mains, Center, Surrounds. They work great.
Danzilla31
Agreed if I had to do it over again I'd go with the 2200 I like the idea of every speaker having its own power supply
Plus if one goes out it's easy to replace them they have great sales on them as well
It's very well reviewed and measures very well
Outlaw usually always exceeds there specs goid company
Danzilla31
The monoprice 5 channel is a good amp tho were not bashing it
For myself tho heavy bulky amplifiers when you have solutions like the outlaw 2200 man I'm tired of installing heavy hot bulky amps
It's why I use crowns in my bedroom setup
the machine
the machine
Yeah, I've been reading the 2200 thread on this forum which has a lot of activity lately. At $799 for 3 shipping included, it seems like the best option. I can take the remining $500 and get the Prime Bookshelves for the rears and be at the same price as the monoprice. Thanks to everyone for their suggestions. Placing order now!!!
Danzilla31
Can't wait to hear your impressions! Good choice!
the machine
the machine
Currently I have an Ikea TV stand (TV is wall mounted but holds receiver, Blu-Ray Player, PS3, etc) and is enclosed with glass doors. How hot do these run in an enclosed unit? I previously had a Denon x5200w and I could notice the heat after being on for a while, and I never pushed it as it was in my living room in a prior house, with a young child. Would it be more beneficial to look into an audio rack? Ideally I'd like everything to be enclosed (5 year old and 14 month old) but if heat will be an issue, I'd make the investment in an open rack. Also, what fans should I look into?
the machine
the machine
Update.
All, room is nearly finished, trim goes in tomorrow then we’re done. You’ll notice the room is a different color too. The gray was too light I felt.
Anyways, two questions. Should fronts and subs be as placed, or swap them? I’ve seen them both but I’m not sure which is best. Second, my amp didn’t give me an option for .4 in heights during setup. It asked if I had heights and only said none or two. How can I set this up?
KEW
KEW
The 2200 will run quite a bit cooler than the Denon X5200W! However, I do not like the idea of putting them into an enclosed cabinet without ventilation. I would add an AC Infinity fan to exhaust air at the top of the cabinet.
You want to control where the air is drawn into the cabinet such that the air is pulled across/through the gear to provide optimal ventilation! I usually drill a pattern of holes in the shelf under a unit that matches the location of the venting at the bottom of that electronic component.
If you have ever lived with an attic fan, then you already understand how you control the flow by where you allow the air to enter!
Another great addition to your tools is one of these laser thermometer guns for measuring the temps of your gear and seeing how much difference the added fans make. At $30 from Lowes, this is a good one ($35 from Home Depot if you don't have Lowes nearby)!
ryanosaur
ryanosaur
Cubbies are bad... I agree with KEW on the cooling. I use an AC Infinity Aircom unit in my system; good gear.
In terms of gear placement, my immediate instinct is to bring the front speakers in by at least 2 feet. Personally I would crawl out the sub placement. Front wall may work, but every room is different. If your mains are capable, then they will be outputting some lows, even crossed at 80, and spreading the subs around will help activate more room modes, thus evening out bass response.
Cheers!
the machine
the machine
Thanks guys, I took the doors off of the cabinet and will upgrade to a nicer cabinet in time. At least with the doors off the air will flow more freely. The back of the cabinet is pretty much wide open also.
In terms of sub placement, everything is wired in wall already, so the subs will be along the front wall. It’s just a matter of having them inside vs outside of the towers, which a few feet may be negligible anyways. Just wasn’t sure if having them more angled toward the MLP would be better or worse when multiple people are watching. The closer to the tv the less of an angle and vice versa.
Pogre
Pogre
My Ultra towers and center are powered with a Monolith 7 and there's no lack of dynamic range. I have no problem recommending any of their amps. I went with the 7 because the value jumps a little the more channels you get with this amp. Plus I'm future proofed for atmos or a zone 2 or whatever else my audio-diseased imagination can think of.
Another bonus, I have my receiver set on eco mode since adding the amp and it runs waaaayyy cooler now.
William Lemmerhirt
William Lemmerhirt
Well even if the subs are wired in wall, you can still run cables to where you want them. However, if that’s your main display, I would move the mains in a little closer to the tv and load the subs into the corners and excite all the room modes you can and let audyssey pull down the peaks. If the mains are too far from the tv, on screen images panning off screen, will teleport over to the speaker without tracking the image smoothly from the center channel. You’ll need to experiment with how far away you can put them, as well as how much toe in is best.
