M MK1984 Enthusiast Feb 16, 2024 13 0 1 42 Feb 16, 2024 #81 TLS Guy said: That is just the spray finish coming off. It is purely cosmetic and won't affect performance. So unless you leave it with the grill off, it is of no concern. Click to expand... Spray Finish?
TLS Guy Audioholic Jedi Oct 30, 2007 27,291 0 113 79 Eagan MN Feb 16, 2024 #82 MK1984 said: Spray Finish? Click to expand... The grey is that actual color of the surround. When you turn up the magnification of the picture, you can see something has been sprayed on it.
M MK1984 Enthusiast Feb 16, 2024 13 0 1 42 Feb 16, 2024 #83 TLS Guy said: The grey is that actual color of the surround. When you turn up the magnification of the picture, you can see something has been sprayed on it. Click to expand... I wiped it off.SVS said ist was Talkum (talc)
TLS Guy Audioholic Jedi Oct 30, 2007 27,291 0 113 79 Eagan MN Feb 17, 2024 #84 MK1984 said: I wiped it off.SVS said ist was Talkum (talc) Click to expand... I looked into this. Surrounds are sprayed with a variety of products, but the manufacturers usually keep it a guarded trade secret for some reason. Whatever SVS are using is obviously not stable. I suppose it is possible that it might affect performance, but I had assumed it was largely cosmetic, but since it seems to be such a great secret, may be not.
lovinthehd Audioholic Jedi Sep 11, 2012 44,868 0 113 Oakridge, OR Feb 17, 2024 #85 MK1984 said: I wiped it off.SVS said ist was Talkum (talc) Click to expand... So what was wrong after you wiped it off other than what you "heard" were problems with the driver. Seems like a lot of bullshit going here....
M MK1984 Enthusiast Feb 16, 2024 13 0 1 42 Feb 17, 2024 #86 lovinthehd said: So what was wrong after you wiped it off other than what you "heard" were problems with the driver. Seems like a lot of bullshit going here.... Click to expand... I wiped it off. It still bothered me. A new device should be flawless.That was the point
lovinthehd Audioholic Jedi Sep 11, 2012 44,868 0 113 Oakridge, OR Feb 17, 2024 #87 MK1984 said: I wiped it off. It still bothered me. A new device should be flawless.That was the point Click to expand... But worked fine for two years plus?
M MK1984 Enthusiast Feb 16, 2024 13 0 1 42 Feb 17, 2024 #88 lovinthehd said: But worked fine for two years plus? Click to expand... I haven't had much time to use the home cinema in the last 2 years. It was irrelevant. I still got annoyed when I walked past it.
