Thanks for this review. Clearly a lot of work.
You talk about DPL IIx. There are also a number of THX modes, which are a bit of a mystery:
Assuming that you can set your cross-overs frequency to 80Hz without applying THX processing, why would you apply THX processing to a THX DVD (which presumably has had cinema brightness removed as part of the THX-approved mastering process)?
There is a further dimension to all this. THX processing seems to use ASA to derive 7.1 signals from 5.1 tracks. But the same can be achieved with DPL IIx.
For example, the manual says:
THX Ultra2 Cinema: THX processing for non EX/ES encoded 5.1 channel sources. This program outputs sound from the surround back L/R speakers using ASA (advanced speaker array) processing. This mode is only available when you have set up a 7.1 speaker system (i.e. two surround back speakers), and the input signal has surround left and surround right contents.
THX Ultra2 Cinema mode plays 5.1 movies using all 8 speakers giving you the best possible movie watching experience. In this mode, ASA processing blends the side surround speakers and back surround speakers providing
the optimal mix of ambient and directional surround sounds. This mode permits the playback of a non Surround EX/ES encoded 5.1 movie to be played back over a 7.1 system. DTS-ES (Matrix and 6.1 Discrete) and
Dolby Digital Surround EX encoded soundtracks will be automatically detected, if the appropriate flag has been encoded. Some Dolby Digital Surround EX soundtracks are missing the digital flag that allows automatic
switching. If you know that the movie that you are watching is encoded in Surround EX, you can manually select the THX Surround EX playback mode (see below), otherwise THX Ultra2 Cinema mode will apply ASA processing to
provide optimum replay.
But there is also
THX Cinema: THX processing for any multi-channel source. 2-channel sources are decoded by the PRO LOGIC, PRO LOGIC II, PRO LOGIC IIx or DTS Neo:6 decoder before THX processing.
which may be preferable if you prefer DPL or DTS Neo over ASA?
For 6.1 sources, there is:
THX Surround EX: THX processing for Dolby Digital and Dolby Digital EX sources. This program is available only when surround back L/R speakers are connected to this unit and when the input source contains surround back channel signals.
THX Surround EX - Dolby Digital Surround EX is a joint development of Dolby Laboratories and the THX Ltd.
In a movie theater, film soundtracks that have been encoded with Dolby Digital Surround EX technology are able to reproduce an extra channel which has been added during the mixing of the program. This channel, called
Surround Back, places sounds behind the listener in addition to the currently available front left, front center, front right, surround right, surround left and subwoofer channels. This additional channel provides the opportunity for more detailed imaging behind the listener and brings more depth, spacious ambience and sound localization than ever before.
Movies that were created using the Dolby Digital Surround EX technology, when released into the home consumer market may exhibit wording to that effect on the packaging. A list of movies created using this technology
can be found on the Dolby web site at
www.dolby.com. A list of available DVD software titles encoded with this technology can be found at
www.thx.com.
Only receiver and controller products bearing the THX Surround EX logo, when in the THX Surround EX mode, faithfully reproduce this new technology in the home.
This product may also engage the THX Surround EX mode during the playback of 5.1 channel material that is not Dolby Digital Surround EX encoded. In such case the information delivered to the Surround Back channel is program dependent and may or may not be very pleasing depending on the particular soundtrack and the tastes of the individual listener.
and a similar mode for DTS ES sources.
I can just about follow this, but then there is also
THX DD+PLIIx Movie: THX and Dolby Pro Logic IIx Movie processing for Dolby Digital sources. (and similarly for DTS 5.1 and for DTS ES Matrix 6.1)
How does this differ from THX Cinema?
Can anyone make sense of all this?
