I have just recieved a Denon DVD player 5900 and have a 3910 on the way for comparison, but at the moment, to use up time, I am trying to set up DVD Audio via Analogue connections and MULTI CH IN and need some help in figuring out how the Z9 works with its PURE DIRECT mode.
Basically, steps I have already taken with a SPL meter are:
I have fully setup my speakers so that they all are the same levels with the Z9 internal test tones. So all digital signals that are decoded are fine/equal.
I then, using the MULTI CH IN on the Z9, set up the 5900's levels with the internal 5900’s pink noise. I then confirmed the levels were ok with the Chesky DVD-Audio setup disk, DVD audio seems to be a bit differnet from DD or DTS. Anyway.
So now all my speakers are at the same levels, when using the DVD players decoding via analogue, or with digital connections.
When I play a DVD Audio disk, I just have the Z9 on MULTI CH IN and STRAIGHT, everything is ok, sounds great, and levels are ok.
But what if I want to use PURE DIRECT with MULTI CH IN. Does this then bypass even the speakers levels setup on the Z9, stuffing up the volumes of each speaker as now only the DVD's speaker level setup is being used. (Which, on it's own, the 5900’s levels are incorrect, it needs the Z9's level on top to even out)
What do you do in this situation? I do not want to set the 5900's level so they are correct, while the Z9 is in the PURE DIRECT MULTI CH IN mode. As sometimes you may want video in the background, which the Z9 will cut off, or to apply a DSP.
Or do I just not listen to the MULTI CH IN in PURE DIRECT mode.
Please let me know.
And I know it would be better off using the iLink connection, but the cable was missing out of the DVD box so I am waiting for that too, and as I said earlier, I would just like to find out anyway
Simply, does the PURE DIRECT mode bypass even the speaker channel level setup.
Thankyou
KJ
