Gene I whole heartedly agree with your stance on receivers vs seperates, l too am not against seperates, I fact I owned a 5.1 seperate setup prior to what I have now. I challenge anyone to find a seperate preamp/proccesor that is as good as and has the feature set of A Denon 2803 at twice the price?
Dolby Digital Surround EX, Pro Logic II decoding with Cinema and Music Modes*•*DTS Extended Surround Discrete 6.1 decoding*•*DTS Extended Surround Matrix 6.1 decoding*•*DTS Neo:6 Cinema & Music Surround decoding*•*DTS ES 96/24 5.1 decoding for DVD Video *•*Analog Devices Melody 100, 32 bit floating point DSP processor*•*16 Analog Devices 24 bit, 96 kHz high resolution DACs on all eight channels, in differential configuration*•*Real 24 bit, 96 kHz Digital Interface Receiver*•*Adjustable High and Low Pass Crossover (40/60/80/100/120Hz)*•*2 Assignable component video inputs (100MHz)*•*7 sets composite and "S" video inputs*•*7.1 external wide bandwidth (100 kHz) analog inputs for future multi-channel formats (such as DVD-Audio)*•*5/7 Channel Stereo*•*Personal Memory Plus*•*6 assignable digital inputs (4 Optical, 2 Coaxial)*•*2 Optical digital outputs*•*9 analog inputs including built-in AM/FM tuner*•*Multi-Zone 1 stereo pre-amp level audio outputs*•*Power Amplifier Assign function, lets you assign 2 of the 7 amp channels to drive second zone speakers directly
Plus the 7x90watts per channel
I paid $650.00 for mine. I doubt you will find a seperate at $1200 that will have all that and then you still have to get an amp or amps. At this time seperates are not the way to go, unless your funds are not an issue.
