Yamaha AVENTAGE 2021 AV Receivers Bulk Up on Power and 8K Features
  • Thread starter Thread starter gene
No, the AVR is being used as the preamp/amp for the karaoke mixer. :D
The point is that there are many casual applications where using a high-end separate system isn’t quite necessary.
My Bryston 9B-cubed and ATI AT2005 amps aren’t being used for karaoke. :D
What's the mixer? Just curious
Room size, speaker efficiency, and desired volume would dictate whether one needs an AVR or separates. I know that for my dedicated room, separates would absolutely offer no sound quality improvement over the 3060. My room is small and my speakers are very efficient. The 3060 is loafing along.
Well I can understand using separates for your main system.
May-be I'm crazy, some have a different opinion on my state of health. But everything I use, is a mono-bloc system, Except for the theatre system which uses a five channel amp.. At one time i used to have / own or beg, borrow of steal different speakers, which required solid amplification Equinox being one brand with models going down to a 2 ohm load. Unfortunately Equinox are no longer in production.
I'm not into all these fancy sound systems with a speaker collection hanging of the ceiling. Personnel I think there a complete waste of time, and small amount of money people spend. Filling up all the connections on there AVR, and convincing themselves it''s all Utopia , and the best ever. With Helicopters flapping over the back of the lounge chair
Frankly a good brand of speakers, Magico etc, together with a good amplification leaves, your so-called theatre system for dead. And people react in horror when they learn I don't own a sub wooofer. Which in most cases are a marketing ploy, to flog stuff the gullible are buying something they don't need., but must have because everyone else has one.
My wife would sing karaoke in our bedroom
With due respect, I've never confronted that problem, Are you sure your not ready for the retirement home, where you can sit on the verandah, and dream of past glories ,
More tea Vicar.
But a small personal question, do you conduct while she's singing.
@Monobloc.... You couldnt be more wrong about subwoofers and the value they add to a system's sound. Too much information about subwoofers out there is proving you wrong right out of the starters gate. Just sayin
  • Agree
Reactions: everettT
I have mine in a hybrid setup, the AVR could not cope with my tricky (1.6ohm minimum impedance) front speakers, but it handles the surrounds and heights just fine.
So I run external power amps and use the AVR as an AVP for the fronts, but as an AVR of the rest.
An AVR with pre-outs is in many such cases, essential - many of the budget AVR's don't provide pre-outs which then limits their use! (eg: Onkyo NR7100, no pre-outs, vs Integra DRX3.4 with full pre-outs... they are otherwise identical!)
Yamaha MG12 Mixer.
That's a real nice soundboard for the price. I have an MG16XU that I use for live performances and have been pleased with it's performance. I have a PreSonus Studio Live 32 that I use at Church, but is way to much to use for live performances with the programming that is required.
  • Like
Reactions: AcuDefTechGuy
I should have factored in impedance as well but having that low of an impedance is more uncommon than common.
I think you might be surprised at how many popular speakers have an impedance at 4ohms or below that occurs in the powerband and between 100 and 400hz. This, obviously, is irrelevant at lower volumes, but will cause issues at moderate volumes. Example being the new Adrenal 1528, the phase angle isn't horrible but the EPDR is pretty low
I think you misunderstand me. I quoted dlaloum whose speakers dip into 1.6 ohm range. That is more uncommon than common. All of my speakers dip into the 4 ohm range and that is all too common. I stand by what I said earlier.
All my Yamaha AVRs, RX-A 1060, 2060, and 3060 are still running flawlessly
I have an RX-V800 (2003) on a shelf downstairs that was still going strong up until I replaced it a few years ago. The volume knob was getting a bit glitchy but may just require a little cleaning.
I believe there may still be an RX-V990 (1996) up at the family cabin too. Although I'm not sure if anyone has actually turned it on recently to verify it if is also still working all these years later.
The Yamaha's I've had experience with have all been solid and reliable for many, many years.
  • Like
Reactions: 3db
I guess I did, you said the 4ohm dips are more uncommon than common. I replied it's common and the EPDR is even lower. Not sure where the disconnect is?
The disconnect was speed reading.. :)
I said "I should have factored in impedance as well but having that low of an impedance is more uncommon than common." I did not say anything about 4 ohms. I could have been clearer stating 1.6 ohms as mentioned by dlaloum. Its all good in the hood. :)
  • Like
Reactions: everettT
I guess I should have factored in "that low", my bad.
  • Like
Reactions: 3db
Yes, it is uncommon, but it is also a "gotcha" - as the manufacturers do not (usually) advertise their full frequency impedance curve...
All you can say, is that if running 4 ohm (nominal) speakers... you should be cautious, and typically, 8ohm (nominal) speakers, are pretty safe.
So I do tend to warn people ... the low impedance thing can drive you nuts, as the system doesn't sound right, but there is no obvious reason for it... which can lead to random upgrades, and discussions about how different amps "sound different" (yeah they often misbehave differently under low impedance conditions, and their distortion patterns differ...).
And then you try an amp that is stable into 1ohm loads, and suddenly the midrange clicks into place, imaging stabilises, dialogue is intelligible.
It is a frustrating and pernicious problem... (if you have it) - and typically you can only uncover that root cause by finding a proper lab test of the speaker where the full impedance/frequency is mapped....
(and just to exacerbate the problem, most amp manufacturers don't publish data on their 2ohm or 1ohm capabilities....)
  • Like
Reactions: everettT
This might be true if your running tiny speakers connected to a equally cheap and nasty AVR..So a Sub
might well be needed to equal out the sounds ballance, as the low end speakers simple can't handle the sound.
Get into the real audio world and AVR's and Sub's are a non-event. Check out sites like Audio Shark and
What's Best, and you will never see AVR's discussed. There simply a non event, The same goes for Sub's.
Consider any quality Pre-amp and there's simply no connections for a sub.
  • Dumb
Reactions: 3db
I, almost, assume that most speakers today dip into the 4ohm range, definitely not all, but a large market segment and anyone who listens to their content loudly should be aware and purchase accordingly. It's not the 70s anymore and speakers aren't 16ohm nominal based on design.
  • Like
Reactions: dlaloum
I have speakers that are truly full range and I still use subs with them, with an AVR acting as a preamp. They sound glorious:)
I do love me some big full-range towers of power with dual 12” or 10” woofers.
  • Like
Reactions: dlaloum
It appears to me that you have your head firmly placed up the audiophile's proverbial ass swallowing all the audiophile nonsense that they feed you. Ignorance is bliss and you demonstrate that in spades. Like I said earlier, there is too much real data out there that firmly establishes the benefits of a sub in an audio chain despite your strawman arguement of avp not having a sub out.
