KING DRANZER Full Audioholic Jan 19, 2026 #21 William Lemmerhirt said: What is the budget here? Click to expand... Including AVR/Processor + AMP + Projector + Projector Screen + Cables,Mounts etc. It is around $45-50k
KING DRANZER Full Audioholic Jan 19, 2026 #22 AcuDefTechGuy said: You like the 10” woofer on the Sourcepoint-10 bookshelf? 10” = 78.5 square-inch. RBH 831 bookshelf and In-wall speakers have 5” tweeter + 3 x 8” woofers = 150.7 square-inch woofers. RBH 821 bookshelf and in-wall speakers hasve 5” tweeter + 2 x 8” woofers = 100.5 square-inch surface area. Other speakers also have big dynamics BOTH tweeter and woofer. Click to expand... That is crazy expensive.
William Lemmerhirt Audioholic Overlord Jan 19, 2026 #23 KING DRANZER said: Including AVR/Processor + AMP + Projector + Projector Screen + Cables,Mounts etc. It is around $45-50k Click to expand... Oops. I guess I meant what’s left for speakers and subs.
KING DRANZER Full Audioholic Jan 19, 2026 #24 William Lemmerhirt said: Oops. I guess I meant what’s left for speakers and subs. Click to expand... I meant speakers to be part of that $45-50k including other stuff. No dedicated budget for Speakers. But going for JVC NZ700 + 175" screen so that be $13k combined.
AcuDefTechGuy Audioholic Jedi Jan 19, 2026 #25 KING DRANZER said: That is crazy expensive. Click to expand... Just don’t pay retail.
S shadyJ Speaker of the House Staff member Jan 19, 2026 #26 KING DRANZER said: Yes. I think @shadyJ would have experience it for sure. I be surprised if he did not. Click to expand... I have heard Planar tweeters in MTM configurations. It can work if executed correctly, as with so many other design types. RBH does this very well with AMT tweeters.
KING DRANZER Full Audioholic Jan 19, 2026 #27 shadyJ said: I have heard Planar tweeters in MTM configurations. It can work if executed correctly, as with so many other design types. RBH does this very well with AMT tweeters. Click to expand... How do they stack up against KEF speakers. Specially when it comes to depth of field.
Kingnoob Audioholic Ninja Jan 20, 2026 #28 AcuDefTechGuy said: You like the 10” woofer on the Sourcepoint-10 bookshelf? 10” = 78.5 square-inch. RBH 831 bookshelf and In-wall speakers have 5” tweeter + 3 x 8” woofers = 150.7 square-inch woofers. RBH 821 bookshelf and in-wall speakers hasve 5” tweeter + 2 x 8” woofers = 100.5 square-inch surface area. Other speakers also have big dynamics BOTH tweeter and woofer. Click to expand... is Sourcepoint paper woofer somehow ultra high end paper? Seems cheap speakers use paper also as do expensive subs like rythmic. Wow bet there pricey but endgame! Who knows current prices. RBH Sound Massive AMT In-Wall & Active Speakers, and Dual 12" Subwoofer RBH Sound released 3 new products, SI-831R is a new in-wall LCR speaker designed to fit behind an acoustically transparent screen, the S-1212 12" dual-driver subwoofer, and the PM-8 powered studio monitor. www.audioholics.com
S shadyJ Speaker of the House Staff member Jan 20, 2026 #29 KING DRANZER said: How do they stack up against KEF speakers. Specially when it comes to depth of field. Click to expand... I haven't done a back-to-back comparison, so I couldn't say. The RBH speakers will likely have a wider dynamic range though.
S shadyJ Speaker of the House Staff member Jan 20, 2026 #30 Kingnoob said: is Sourcepoint paper woofer somehow ultra high end paper? Seems cheap speakers use paper also as do expensive subs like rythmic. Wow bet there pricey but endgame! Who knows current prices. RBH Sound Massive AMT In-Wall & Active Speakers, and Dual 12" Subwoofer RBH Sound released 3 new products, SI-831R is a new in-wall LCR speaker designed to fit behind an acoustically transparent screen, the S-1212 12" dual-driver subwoofer, and the PM-8 powered studio monitor. www.audioholics.com Click to expand... Paper can be an excellent driver material. While it is not the stiffest stuff out there, it doesn't have as fierce breakup modes as most other materials. And keep in mind that the 'paper' used in loudspeaker cones is not much like paper you are used to in magazines and books; it is a much tougher material which is usually treated with resins or other fibrous materials.
KING DRANZER Full Audioholic Jan 20, 2026 #31 shadyJ said: I haven't done a back-to-back comparison, so I couldn't say. The RBH speakers will likely have a wider dynamic range though. Click to expand... I think it has to do with the driver placement like with their higher end towers where they have drivers ti the side and above and below the tweeter. That helps with depth of field. I only got to experience it once in a 2ch setup and it was decent. But also crazy expensive. Do they have similar driver layout for lower end models. Will have to check.
KING DRANZER Full Audioholic Jan 20, 2026 #32 AcuDefTechGuy said: Just don’t pay retail. Click to expand... What would the SV-831R cost. If I be getting 831 that will the one. Not getting Regular M-T-M-M speaker. I want that M-MT-M layout. That is what I heard and possibly due to its driver layout it got that depth of field that I am looking for.
