Dear MacManNM,
When Tom Nousaine measured the STF-1 (which has an 8" driver and a 3" flared port), he noted that it "delivered a minimum of 101db's at any frequency above 25Hz", and had bandwith uniformity of 98% in the 25-62Hz range. When we tested the STF-1 outside from at least 1 meter away, we found that response at 100db was basically flat to 30Hz, and around -8db's at 25Hz (note that in-room measured response should be somewhat better due to boundary reinforcement). So overall not bad, and some useable output below 30Hz in small to medium sized rooms, especially when placed in nearfield position.
Within each manufacturer's respective lineup, a subwoofer with a larger driver will tend to give enhanced output and low end frequency response versus a subwoofer with a smaller driver. However, when comparing subwoofers from different brands, there are many other variables to consider. Ported or sealed, enclosure size, amplifier power, driver qualities, tuning point, and so on and so forth.
Ultimately there are very good quality products available from a variety of different manufacturers that come in all shapes and sizes. I do have respect for those who try first and foremost to provide quality audio components for the lowest of budgets. Cadence seems to be doing just that.
Sincerely,
