My Rythmik FV18 is Broken. Next steps?
  • Thread starter Thread starter mx416
Simple, I pulled the amp and wired the crown through the existing opening to the xlt input, could have done it through the rca but it was easier than the rca input, just easier that way.Just took advantage of what was there.
My point was that most people (including myself) would not feel comfortable doing that since most of us aren’t exactly DIY like you and TLS. :D
Sub Amp gone? I’ll just buy another one. Don’t have to mess with the sub itself. Easy peasy.
But anyway, yeah we’re jacking this thread for sure. :D
I have my old Epik Empire and thought of doing that too, but this one is also a servo sub and decided not to. SB-4000 is a LOT smaller :) yet still has good output.
  • Like
Reactions: everettT
Might be heavy to move to side to get to amp plate. 18inch is a larger sub.
Probably 90% of us can handle a few screws and unplug 2 wires going to the woofer though. It’s easy. :) Brian at Rythmik can talk them through it.
  • Like
Reactions: everettT
Rythmik were the first ones I called. None of their amps will directly work for the Empire.
Epik had sent me one replacement amp already free and it was a straightforward replacement. 2 or 3 wires, no soldering.
  • Like
Reactions: everettT
Am I reading that correctly that the Epik Empire is a servo sub? Not heard that before in any case.
Not to my knowledge and definitely not according to the wiring. He may be referring to the replacement amp he was looking at from rythmik amp fitting. I wired the Empire exactly as it was from the factory and there was no servo board.
  • Like
Reactions: lovinthehd
Yeah have an Empire myself, still doing well (altho did have an early amp failure/replacement under warranty). I misread the post it seems
  • Like
Reactions: everettT
Just an update,
Brian got my amp and tested it. It looks to be a bad power amp module (Hypex). He will replace and send back. Overall a pretty cheap fix. I’m thankful for that. I really like the subs so this outcome is pretty much as good as it could get.
Just an update,
Great news. Wonder if amps degrade not in usage? I have one upstairs collecting dust an old diy.
You’ve never heard people complain about their sub amps die and they can’t replace them and don’t know what to do?
If the sub amps were separate (QSC, Crown, etc.) they could easily replace the amp.
They don’t have to be separate to be easily replaced. People today are so fukking dumm and lazy, and can’t problem solve a runny nose for Christ sake. A few screws and a couple wires are a deal breaker? People complain about all kinds of things. “Don’t know what to do”? Whah whah. Call mommy…
  • Agree
Reactions: everettT
I wouldn't call anyone "fukking dumm" or "lazy" when they have Doctorate and multiple degrees and just because they don't feel like doing something with a subwoofer.
Does it make you feel smarter or harder working just because you can unscrew some screws on a sub?
I know plenty of people of multiple degrees and doctorate degrees who think that people without at least an engineering degree are a bunch of idiots, especially people who spend money on audio. But it's not true either.
There are certain things we feel like doing and some things we don't feel like doing.
Advanced degrees are no insurance against not being dumb as rock in practice. I worked with a delightful Russian colleague who could sum it up. He once referred to one of our problem colleagues as:- "One of those physicians who is wrong more often than by chance!" That is one of those glorious quips I will never forget.
  • Agree
Reactions: everettT
That’s not the POINT.
The point is that you should NOT judge someone just because they aren’t willing to do something or aren’t interested in doing it.
Not jumping back off topic much but this post by Floyd Toole, specifically the last line, is a good one. Note he doesn't mention internal or external amps, but active speakers in general.
Post in thread 'Why evaluating the sound of a single speaker is essential' https://www.audiosciencereview.com/...ingle-speaker-is-essential.62656/post-2447373
There are theoretical advantages to active speakers (internally or externally powered).
But theories and reality are not always the same. I have owned the 100% fully active Linkwitz Orion 3.2.1, which required 8 Channels of external ATI Amps and external EQ/DSP. Some critics proclaimed it was among the best in the world. I subjectively think it did NOT sound ANY BETTER than other passive speakers, including RBH, Revel, B&W, KEF, etc.
So - it's cool whatever people want - passive-active, internal-external-power.
The fact is that it is simpler for most people to just replace the external amp vs having to ALTER the built-in sub-amp to bypass the built-in amp.
But it's cool whatever people want.
  • Like
Yeah, sorry for the confusion. I already had access to a non-servo amp from them that was being used for my former sub, but they only had 2 offerings at the time and Rythmik said neither was suited to that sub. And of course, the servo amps would not work.
  • Like
Reactions: everettT
Just an update,
Thats great news!!!
I view it more as what is more appropriate for a given time/system. It may well move to active/powered speakers more and more, tho that may not make sense for your use now.
