i need some advice on my next sub!
William Lemmerhirt
William Lemmerhirt
Fresh only or fresh roasted (on further pondering :) )....hate the pickled ones. I use them in cooking the pork as well as some other sources of heat, too.
Fresh or pickled for me, depends on what I’m doin. Also, candied jalapeños(cowboy candy is another name), are very nice on many things.
William Lemmerhirt
William Lemmerhirt
Never saw the candied ones....
I don’t know if they’re available in stores that way. We made our own after trying some at a family gathering a few years ago. Sweet plus heat. Mmmmmmm
Edit: Was gonna share a link. But if you put a search in googletron there’s an endless list of recipes. Lot of prep work. Not sure that’s your thing or not. Lol
Pogre
Pogre
I put fresh Jalapeños in everything. Just the right balance of heat and pop of freshness. I ALWAYS have a couple in the crisper.
Pogre
Pogre
Protip: ALWAYS wash your hands after seeding and chopping Jalapeños, ESPECIALLY before taking a leak and touching your junk!
I speaketh from experience...
Trell
Trell
Not the hotness you where looking for? :p
Same for several other types of chili, at least when accidentally touching the eyes. I've not tried your junk thing, and have no immediate plans for it either.
I too speaketh from experience...
Mikado463
Mikado463
Not a problem, I'll just be careful when I change my Depends ............
jsf0656
question? if i wanted to add a second sub and my yamaha only has 1 sub output would this be possible or would i need to get another receiver with 2 sub outouts?
ryanosaur
ryanosaur
You can use a y-splitter to do this, but the best succes in a situation like this would come from keeping the subs equidistant and symetrical.
A true dual Sub AVR which will allow you to control distance and trim for both individually would be better (some AVRs just use the single Sub approach with an internal Y).
A better approach given the limits of your AVR would be to implement a MiniDSP 2x4 and Room EQ Wizard to program it. This gets more expensive, but will allow you to manage delay and volume individually along with managing EQ for the subs. This is an advanced approach and will take time and effort as well as extra cost to implement.
Pogre
Pogre
You can use a splitter to add a second sub, no problem. Something like this.
Pogre
Pogre
Jinx!
jsf0656
i need some instruction here. how do i connect to and from receiver and the 2 subs?
Pogre
Pogre
You plug the splitter into the sub out on your receiver then run rcas from the splitter ends to your subs.
ryanosaur
ryanosaur
Also if your subs allow it, you can daisy chain, too.
jsf0656
thanks again. thinking now about going dual with my setup. my yamaha is 80w/ch with 2ch driven so just using the 2 ch for stereo has worked great and sounds good but doing dual subs with a splitter will that affect the sound quality in any way?
ryanosaur
ryanosaur
no.
The wattage output for your speakers is a different thing, the subs only get a very low voltage pre-out signal from the avr.
