Found one!!
A performer AND a looker
CD player,
DAC,
preamp, amp, tuner, network player,
USB, ipod/iphone dock,
sub out x2 (but with serious specs)
If anyone has some cash he's stumbling upon, I am a mere 3000$ short!
T+A E-Serie Music Receiver
Specifications
Nominal output per channel
2 x 160 Watt into 4 Ohm, 2 x 100 Watt into 8 Ohm
Peak output
2 x 220 Watt into 4 Ohm, 2 x 150 Watt into 8 Ohm
Frequency response
+/- 3dB: 1 Hz - 60 kHz
Total harmonic distortion
< 0,01%
Intermodulation
< 0,01%
Channel seperations
> 80 dB
Inputs
Analogue inputs
3 x high-level (RCA) 250 mVeff ... 2,5 Veff / 20 kOhm
Digital inputs
SP/DIF (16 - 24-bit): 3 x coax (192 kHz), 2 x TOS-Link (96 kHz)2x USB for iPod and Harddisk
Outputs
Analogue outputs
Pre-amplifier output, Line Out, Tape Out
Headphones
> 50 Ohms
Digital outputs
1x coax, IEC 60958 (CDDA/LPCM)
CD-Player
CD/DA, CD-R, CD-RW, CD Text
Streaming Client formats
MP3 , WMA, AAC, OGG-Vorbis, FLAC (192/24 via LAN) and WAV (192/24 via LAN) with gapless playback (where supported by server)
Playlists
PLS, M3U, ASX (if supported by server)
Supported Media servers
UPnP 1.1, UPnP AV, Microsoft Windows Media Connect Server (MS DRM10), vTuner Internet Radio Service, DLNA compatible servers
Standards
DLNA, UPnP, MS-DRM10, Designed to play Plays for sure guidelines
Features
Web server (remote PC Web browser control), vTuner. Internet Radio Station database (automatic updates over Internet)
Interfaces
USB 2.0 for Harddisk, iPod with control system and display, LAN, W-LAN, RS 232 Update and control interface
Radio
FM Radio 87,5 - 108 MHz, overload damping >40 dB, RDS functions, station lists, station memory (presets)
D/A converter
32-bit, 384 kHz Sigma Delta, 8-times oversampling, double-mono
Analogue filter
Phase-linear 3rd order Bessel filter, 100 kSps
Frequency response
2 Hz - 20 kHz 44.1 kSps
2 Hz - 22 kHz 48.0 kSps
2 Hz - 40 kHz 96.0 kSps
2 Hz - 80 kHz 196.0 kSps
< 0,001 %
Signal : noise ratio
109 dB
Channel seperation
106 dB
Dimensions Hx W x D
12 x 44 x 39 cm (4.7 x 17.6 x 15.6 inch)
Weight
10kg (22lbs)
Finishes
black case with silver side panels
silver case with black side panels
black case with black side panels
silver case with silver side panels
Accesories
Includes F 100 system remote control, WLAN aerial, FM aerial
control interface
RS 232 for update and control system
Mains power
220-230 V or 110-115 V, 50-60 Hz, 300 Watt
optional accessories
iPod docking station
FD100 bi-directional radio remote control handset with screen
metal ir remote control FM100
GW E internal radio receiver for MUSIC RECEIVER
