Enter to Win: Wireless Subwoofer from Aperion Audio!
Status
Not open for further replies.
U
utopianemo
Here you go!
1. How important is it to you to match the look of the surround sound speakers with the front speakers in a 5.1 or 7.1 system?
6. Very important: if my wife doesn't like them, I don't buy them.
2. Currently, if you have surround speakers where are they located? If don’t have surrounds, why not?
6. Currently, my surrounds are hidden behind my end tables to keep the kids from destroying them.
3. If there was a high quality wireless surround sound speaker available would you consider it for a home theater system?
4. No, I don’t trust wireless quality yet.
4. Wireless speakers have the amplifiers built in and so they need to be plugged into the wall for power. Would this limit you from considering wireless surrounds?
3. Yes, I want a clean custom installed look, the power cords would be a deal breaker.
5. When you buy audio electronics, some products use an inline power adapter (“Power Brick”/”Wall Wart”). If you are considering a wireless speaker for surrounds and where you’d place them, which would you prefer? (Please choose one)
1. Internal Power Supply, so it has an AC Power cord only.
6. If you were looking for a surround speaker to match your existing front speakers but had to buy another brand, what features would be the most important to you?
4. The sound
rnatalli
d. Somewhat important. I would like to get a matching set, but what works best for my theater/space is of most importance.
b. Wall mounted (Wire under carpet or baseboards)
d. No, I don’t trust wireless quality yet.
c. Yes, I want a clean custom installed look, the power cords would be a deal breaker.
c. Doesn’t matter
d. The sound
bigbassdave
bigbassdave
1. Not important. Sound is what matters.
3. Speaker Stands
4. The sound
rhu71774
5. Very important, if they don’t match the other speakers I’d rather not use surrounds.
This is only because matching the looks means matching the brand/product line to me. And by matching the product line you should also get timbre matching. I know its not vital for surrounds, but why not if you can do it. Its not just good sound quality, but the proper sound to me (throughout the entire system).
3. Speaker Stands
4. Other (Please explain)
The power supply has nothing to do with it for me, strictly the reliability and quality of wireless speakers. It is actually cleaner and cheaper to run speaker wire than it is to run power lines to everywhere you need to place speaker. Wireless speakers have no place in an HT system.
3. Doesn’t matter
4. The sound
Not just that it sounds good, but that it matches the sound as close as possible to the existing speakers.
quern
c. Speaker Stands
a. Yes, a wireless surround speaker would be great.
a. No, I have outlets all over the place.
a. Internal Power Supply, so it has an AC Power cord only.
d. The sound
Josuah
2. Currently, if you have surround speakers where are they located? If don’t have surrounds, why not?[/B]
b+c. I have the rears wall mounted with visible wire and the sides on stands with visible wire.
e. I have no plans to replace my current surround speakers and doing so would require a full matched set and sound quality is more important than wireless.
e. Yes, because I need my home theater gear to connect to specific electrical circuits.
a. Internal power supply.
d. The sound.
drrick
1. Not important. Sound is what matters.​
1. Wall mounted (Concealed wires)​
4. No, I don’t trust wireless quality yet.​
3. Yes, I want a clean custom installed look, the power cords would be a deal breaker.​
3. Doesn’t matter​
4. The sound​
Coult_45
Coult_45
1. D Some what important
2. A Wall mounted (Concealed wires)
3. C Yes, a wireless surround speaker would be great.
4. B No, wireless surrounds are the only solution for my room
5. A Internal Power Supply, so it has an AC Power cord only.
6. D The Sound
armaraas
Contest Questions:
d.Somewhat important. I would like to get a matching set, but what works best for my theater/space is of most importance.
a.Wall mounted (Concealed wires)
d.No, I don’t trust wireless quality yet.
d. A wire is a wire, whether speaker or power, kind of defeats the purpose if you are going for a clean look, however if the outlet wire would be easier to conceal I would consider it.
a.Internal Power Supply, so it has an AC Power cord only.
a.Shape/design of the speaker
K
Ketsueki
c.Speaker Stands
a.Yes, a wireless surround speaker would be great.
b.No, wireless surrounds are the only solution for my room because I can’t get speaker wire there.
d.The sound
Marshall_Guthrie
Marshall_Guthrie
Audioholics Videographer Extraordinaire
5. I don’t have surround speakers because (Actually I do, but we're in the process of moving, so they're not hooked up)
1. Other (No, because for the same money, I'll be able to get a better quality wired solution)
4. Other (No, I would be limited by price vs. quality, as described above)
3. Doesn’t matter
5. Other (Price)
...You might want to hire a survey writer in the future. I took all 3 contest surveys and very few of the answers fit. I don't know how useful they will be for info collection purposes.
L
LabRat
Contest Questions:
4. Somewhat important. I would like to get a matching set, but what works best for my theater/space is of most importance.
4. Bookshelf
5. Other (Please explain) Still would have to run power to speakers and lines from the rear receiver... so far would rather just run speaker lines. I can se where in some rooms it may be useful.
4. Other (Please explain) yes, in my rooms (see above), it is not a big deal to just run speaker wire...
1. Internal Power Supply, so it has an AC Power cord only. (as long as adequate heat dissipation is designed in)
4. The sound
Thanks and good luck to all.
X
x2turbo
Speaker Stands
The sound
mrdockery
Contest Questions:
The sound
tattoo_Dan
tattoo_Dan
To be eligible to win, you must: 1) Be a registered Audioholics forum
  • Not important. Sound is what matters.
  • Not important. My surround speakers are on the other side of the room so it doesn’t really matter if they all match or not.
  • Not important. My subwoofer doesn’t match anyway.
  • Somewhat important. I would like to get a matching set, but what works best for my theater/space is of most importance.
  • Very important, if they don’t match the other speakers I’d rather not use surrounds.
  • Other (Please explain)
  • Wall mounted (Concealed wires)
  • Wall mounted (Wire under carpet or baseboards)
  • Speaker Stands
  • Bookshelf or end tables
  • I don’t have surround speakers because (Please explain)
  • Yes, a wireless surround speaker would be great.
  • Yes, I have a difficult room that doesn’t allow me to conceal the wires.
  • Yes, but only if I could find wireless surrounds that matched my current speakers.
  • No, I don’t trust wireless quality yet.
  • No, I have outlets all over the place.
  • No, wireless surrounds are the only solution for my room because I can’t get speaker wire there.
  • Yes, I want a clean custom installed look, the power cords would be a deal breaker.
  • Internal Power Supply, so it has an AC Power cord only.
  • Inline Power adapter such as Power Brick or Wall Wart with thin DC power cord going to the speaker.
  • Doesn’t matter
  • Please explain
  • Shape/design of the speaker
  • The size of the speaker
  • The finish/color of the speaker
  • The sound
  • Other (Please explain)the sound,and a matching timbre is important to me
Note this contest ends on March 31st, 2010. Winners will be drawn shortly thereafter.
Have fun and good luck![/QUOTE]
hassler
Contest Questions
Doesn’t matter
The sound
StphNieuw
Contest Questions:
[*]Somewhat important. I would like to get a matching set, but what works best for my theater/space is of most importance.
  • Speaker Stands
          • The sound
Rowdy S13
Rowdy S13
Contest Questions:
3. Speaker Stands
I would rather use the amplification from my expensive receiver or amp, that would limit me more than a wire.
3. Doesn’t matter
4. The sound
Sean
Mike8888
5. I don’t have surround speakers because (Please explain) - Still in the shopping phase to decide.
1. Yes, a wireless surround speaker would be great. Especially for the surrounds/ subwoofer
1. No, I have outlets all over the place. While I would prefer not to have to plug each one in, for existing construction homes it would make for an easier install.
1. Internal Power Supply, so it has an AC Power cord only. (preferably removable cord in case a different length is necessary)
4. The sound
*rubs hands together..cooooome on winner entry!!*
nibhaz
nibhaz
a.Not important. Sound is what matters.​
b.Wall mounted (Wire under carpet or baseboards)​
a.Yes, a wireless surround speaker would be great.​
d.Other: It really depends because I have the outlets, but doesn’t it kind of defeat the purpose of a wireless solution if the cables are visible? Obviously there is still the convenience factor, which in some situations would outweigh aesthetics.​
c.Doesn’t matter​
d.The sound​
Status
