Enter to Win: Wireless Subwoofer from Aperion Audio!
Status
Not open for further replies.
Tom Andry
Tom Andry
Speaker of the House
Aperion Audio wants you to win!
Aperion Audio is giving away the chance to win one (1) Aperion Bravus 8A Powered Subwoofer and one (1) Aperion Home Audio Link system which, when used together, give you the option of having a wireless subwoofer to one (1) eligible forum member! The Bravus 8A is priced at $319 and the Aperion Home Audio Link is $149 so the total prize value is $468!
Features of Bravus 8A Powered Sub:
  • Single active 8” aluminum driver
  • 100 watt class A/B amplifier
  • Customizable Crossover from 40-160Hz
  • Internally braced ¾” Ported HDF enclosure
Features of Home Audio Link:
  • Send music from your computer, MP3 player, or other audio source to any audio-video receiver or audio system
  • Wireless Subwoofer - Connect your powered subwoofer or powered speakers wirelessly
  • Audio input via USB or Audio-In Jack
  • Send music throughout your house, or even outside
  • No software needed, just plug and play
To be eligible to win, you must: 1) Be a registered Audioholics forum member, 2) Have USA Residence and 3) Answer the following questions in the thread below.
Contest Questions:
1. How important is it to you to match the look of the surround sound speakers with the front speakers in a 5.1 or 7.1 system?
  • Not important. Sound is what matters.
  • Not important. My surround speakers are on the other side of the room so it doesn’t really matter if they all match or not.
  • Not important. My subwoofer doesn’t match anyway.
  • Somewhat important. I would like to get a matching set, but what works best for my theater/space is of most importance.
  • Very important, if they don’t match the other speakers I’d rather not use surrounds.
  • Other (Please explain)
2. Currently, if you have surround speakers where are they located? If don’t have surrounds, why not?
  • Wall mounted (Concealed wires)
  • Wall mounted (Wire under carpet or baseboards)
  • Speaker Stands
  • Bookshelf or end tables
  • I don’t have surround speakers because (Please explain)
3. If there was a high quality wireless surround sound speaker available would you consider it for a home theater system?
  • Yes, a wireless surround speaker would be great.
  • Yes, I have a difficult room that doesn’t allow me to conceal the wires.
  • Yes, but only if I could find wireless surrounds that matched my current speakers.
  • No, I don’t trust wireless quality yet.
4. Wireless speakers have the amplifiers built in and so they need to be plugged into the wall for power. Would this limit you from considering wireless surrounds?
  • No, I have outlets all over the place.
  • No, wireless surrounds are the only solution for my room because I can’t get speaker wire there.
  • Yes, I want a clean custom installed look, the power cords would be a deal breaker.
5. When you buy audio electronics, some products use an inline power adapter (“Power Brick”/”Wall Wart”). If you are considering a wireless speaker for surrounds and where you’d place them, which would you prefer? (Please choose one)
  • Internal Power Supply, so it has an AC Power cord only.
  • Inline Power adapter such as Power Brick or Wall Wart with thin DC power cord going to the speaker.
  • Doesn’t matter
  • Please explain
6. If you were looking for a surround speaker to match your existing front speakers but had to buy another brand, what features would be the most important to you?
  • Shape/design of the speaker
  • The size of the speaker
  • The finish/color of the speaker
  • The sound
Note this contest ends on March 31st, 2010. Winners will be drawn shortly thereafter.
Have fun and good luck!
krzywica
krzywica
Alright even though I never win anything on these I still fill them out. :)
B. Not important. My surround speakers are on the other side of the room so it doesn’t really matter if they all match or not.
A. Wall mounted (Concealed wires)
D. No, I don’t trust wireless quality yet.
C. Yes, I want a clean custom installed look, the power cords would be a deal breaker.
A. Internal Power Supply, so it has an AC Power cord only.
D. The sound
N
Nugu
4. Somewhat important. I would like to get a matching set, but what works best for my theater/space is of most importance.
4. Bookshelf or end tables (wires run along top of wall, exposed)
4. No, I don’t trust wireless quality yet.
3. Yes, I want a clean custom installed look, the power cords would be a deal breaker.
1. Internal Power Supply, so it has an AC Power cord only. (Unless SQ is effected)
4. The sound
sholling
sholling
D. Somewhat important. I would like to get a matching set, but what works best for my theater/space is of most importance.​
B. Wall mounted (Wire under carpet or baseboards)​
E. Other: I have speaker wires run under the carpet so that's not an issue for me for surrounds and a wireless speaker still needs a power cable so it accomplishes nothing for me. On the other hand wireless would be great for a subwoofer.​
A. No, I have outlets all over the place.​
B. Inline Power adapter such as Power Brick or Wall Wart with thin DC power cord going to the speaker.​
D. The sound, looks and design are nice but it's all about the sound.​
GlocksRock
GlocksRock
The sound
dkane360
dkane360
- Somewhat important. I would like to get a matching set, but what works best for my theater/space is of most importance.
- Wall mounted (Wire under carpet or baseboards)
- Yes, I have a difficult room that doesn’t allow me to conceal the wires.
- Yes, I want a clean custom installed look, the power cords would be a deal breaker.
- Inline Power adapter such as Power Brick or Wall Wart with thin DC power cord going to the speaker.
All the below:
The sound
Bryce_H
Bryce_H
Contest Questions:
a.Not important. Sound is what matters.
b.Not important. My surround speakers are on the other side of the room so it doesn’t really matter if they all match or not.
c.Not important. My subwoofer doesn’t match anyway.
I picked a, b, and c (since they are all correct). However, one thing I will mention is that you generally want a consistant sound from around the room, so the easiest way to get that similar sound is to purchase speakers from the same company and series - hence they will look the same or similar
a.Wall mounted (Concealed wires)
d.No, I don’t trust wireless quality yet.
a.No, I have outlets all over the place.
c.Yes, I want a clean custom installed look, the power cords would be a deal breaker.
I also picked c, except it just means I woudl DIY an additional outlet to the location if there was not one there already. So not a deal breaker, but I do want a clean custom installed look.
a.Internal Power Supply, so it has an AC Power cord only.
I don't want to deal with concealing a brick.
d.The sound
Tonal matching
jwenthold99
jwenthold99
Speaker Stands
Internal Power Supply, so it has an AC Power cord only. It would make it simpler, and you wouldn't have to hide the power supply
The sound
Contest Questions:
1. Not important. Sound is what matters.
3. Speaker Stands
3. Yes, but only if I could find wireless surrounds that matched my current speakers (timbre, not necessarily appearance).
4. Other: Not a deal breaker, but no power wire would likely be a bonus. Less important if we were talking about a sub.
4. The sound
diegs
C. Speaker Stands
D. The sound
ragged
3. Speaker Stands
1. Yes, a wireless surround speaker would be great.
1. Shape/design of the speaker
4. The sound
STRONGBADF1
STRONGBADF1
Contest Questions:
3. Speaker Stands
3. Yes, but only if I could find wireless surrounds that matched my current speakers.
skyline_123
skyline_123
Focusing on mains right now.
Doesn’t matter
riker1384
1. D
2. D
3. E only if they didn't cost too much more than regular speakers
4. D depends on the room and outlet locations. Don't need wireless currently.
5. C
6. D
roscoe1224
a. Not important. Sound is what matters.
e. I don’t have surround speakers because of WAF.
e. Other WAF played a role in the lack of surrounds but I love my LCR setup
a. No, I have outlets all over the place.
b Inline Power adapter such as Power Brick or Wall Wart with thin DC power cord going to the speaker.
4. The sound
jgeorg5
a) Not important. Sound is what matters.
e) I don’t have surround speakers because I live in a condo, and do not have access to the attic to conceal my wires.
b) Yes, I have a difficult room that doesn’t allow me to conceal the wires.
a) No, I have outlets all over the place.
a) Internal Power Supply, so it has an AC Power cord only.
d) The sound
bhodge
  • I don’t have surround speakers because I just moved and currently searching for an upgrade to match the larger room
  • Other - Yes running power to difficult locations is much harder (building codes) than running speaker wire
  • The sound
adwilk
adwilk
2. Not important. My surround speakers are on the other side of the room so it doesn’t really matter if they all match or not.
3. Not important. My subwoofer doesn’t match anyway.
5. Very important, if they don’t match the other speakers I’d rather not use surrounds.
6. Other (Please explain)
1. Wall mounted (Concealed wires)
2. Wall mounted (Wire under carpet or baseboards)
3. Speaker Stands
5. I don’t have surround speakers because (Please explain)
2. Yes, I have a difficult room that doesn’t allow me to conceal the wires.
5. Other (Please explain)
1. No, I have outlets all over the place.
2. No, wireless surrounds are the only solution for my room because I can’t get speaker wire there.
4. Other (Please explain)
2. Inline Power adapter such as Power Brick or Wall Wart with thin DC power cord going to the speaker.
3. Doesn’t matter
4. Please explain
2. The size of the speaker
3. The finish/color of the speaker
4. The sound
5. Other (Please explain) Sound first, then shape/design. For surrounds in a non-dedicated room, these are very close priorities. In a dedicated room, sound.
mudrummer99
3. Speaker Stands
3. Doesn’t matter
4. The sound
Nomo
Nomo
Doesn’t matter
The sound
Status
