Enter to Win: Wireless Subwoofer from Aperion Audio!
Status
Not open for further replies.
Dank
1. How important is it to you to match the look of the surround sound speakers with the front speakers in a 5.1 or 7.1 system?
Not important. My surround speakers are on the other side of the room so it doesn’t really matter if they all match or not.
2. Currently, if you have surround speakers where are they located? If don’t have surrounds, why not?
Wall mounted (Concealed wires)
3. If there was a high quality wireless surround sound speaker available would you consider it for a home theater system?
No there is no reason for high quality surround speakers since most of the sound comes from the front channels. Surround add-ons that cost 150 would be better spent on upgrading the quality of the speakers
4. Wireless speakers have the amplifiers built in and so they need to be plugged into the wall for power. Would this limit you from considering wireless surrounds?
No, I have outlets all over the place.
5. When you buy audio electronics, some products use an inline power adapter (“Power Brick”/”Wall Wart”). If you are considering a wireless speaker for surrounds and where you’d place them, which would you prefer? (Please choose one)
Inline Power adapter such as Power Brick or Wall Wart with thin DC power cord going to the speaker. White color and flat would be nice
6. If you were looking for a surround speaker to match your existing front speakers but had to buy another brand, what features would be the most important to you?
The sound
Tomorrow
Tomorrow
Somewhat important. I would like to get a matching set, but what works best for my theater/space is of most importance.
Speaker stands.
Yes, a wireless surround speaker would be great.
Internal Power Supply, so it has an AC Power cord only.
The finish/color of the speaker.
engtaz
engtaz
e: I listen to SACD and all channel stereo so surround are very important.
a: For rear and c: for side surrounds
c: synergy is important.
a: not a problem
b: less wire size the better
c: and d: but d is the most important.
jijuji
Here go my answers. Still a newbie at this thing... [B said:
Contest Questions:[/B]
[*]Not important. Sound is what matters.
[*]Speaker Stands
[*]Yes, I have a difficult room that doesn’t allow me to conceal the wires.
[*]No, I have outlets all over the place.
[*]Internal Power Supply, so it has an AC Power cord only.
  • The size of the speaker
  • The sound
-Jinx.
abboudc
Contest Questions:
Speaker Stands
just-some-guy
just-some-guy
Other (Please explain) no. because hidding the rca wires are easy. hidding the 120v power is pretty hard to do to code.
Yes, I want a clean custom installed look, the power cords would be a deal breaker.
The sound
Anagoge
Anagoge
4. Somewhat important. I would like to get a matching set, but what works best for my theater/space is of most importance.
Other: In ceiling mounted
1. Yes, a wireless surround speaker would be great, but it depends in the installation, since you still need to run power there.
3. Yes, I want a clean custom installed look, the power cords would be a deal breaker.
1. Internal Power Supply, so it has an AC Power cord only.
OR:
4. Please explain: I might prefer to direct-wire them, meaning I'd run electrical wire mylself, and not use a plug.
All:
1. Shape/design of the speaker
2. The size of the speaker
3. The finish/color of the speaker
4. The sound
project86
Doesn’t matter (either way would be fine)
The sound (other options are somewhat important but in the end sound is what matters most)
njedpx3
njedpx3
Contest Questions:
Other - Fronts and Center need to match to maintain timbre. Other speakers don't need to be the same and/or match to provide excellent sound quality and excellent sound quality is the most important aspect.
Wall (ceiling) mounted (Concealed wires)
No, I don’t trust wireless quality yet.
The sound
Thanks,
njedpx3
(Forest Man)
Jeff R.
Can't wait to win.....
Contest Questions:
  • [X]Not important. Sound is what matters.
    • [X]Wall mounted (Concealed wires)
      • [X]Yes, a wireless surround speaker would be great.
        • [X]Yes, I want a clean custom installed look, the power cords would be a deal breaker.
          • [X]Please explain
            • [X]Shape/design of the speaker
              [X]The sound
jamie2112
Not very inportant
Not room for them
Yes
No, there are plenty of outlets
The sound of the speakers
Chungar
Somewhat important. I would like to get a matching set, but what works best for my theater/space is of most importance. The matching surrounds didn't work for my HT space
Wall mounted (Concealed wires - flat speaker wire)
Other (Please explain) - I just spent $500 on surrounds so I am not interested in any others at this time.
The sound
Other (Please explain)... ALL THE ABOVE
Smartass408
Smartass408
a. Not important. Sound is what matters.
c. Speaker Stands
b. Yes, I have a difficult room that doesn’t allow me to conceal the wires.
b. No, wireless surrounds are the only solution for my room because I can’t get speaker wire there.
a. Internal Power Supply, so it has an AC Power cord only.
d. The sound
AKAJohnDoe
Aperion Audio wants you to win!
Aperion Audio is giving away the chance to win one (1) Aperion Bravus 8A Powered Subwoofer and one (1) Aperion Home Audio Link system which, when used together, give you the option of having a wireless subwoofer to one (1) eligible forum member! The Bravus 8A is priced at $319 and the Aperion Home Audio Link is $149 so the total prize value is $468!
Features of Bravus 8A Powered Sub:
  • Single active 8” aluminum driver
  • 100 watt class A/B amplifier
  • Customizable Crossover from 40-160Hz
  • Internally braced ¾” Ported HDF enclosure
Features of Home Audio Link:
  • Send music from your computer, MP3 player, or other audio source to any audio-video receiver or audio system
  • Wireless Subwoofer - Connect your powered subwoofer or powered speakers wirelessly
  • Audio input via USB or Audio-In Jack
  • Send music throughout your house, or even outside
  • No software needed, just plug and play
To be eligible to win, you must: 1) Be a registered Audioholics forum member, 2) Have USA Residence and 3) Answer the following questions in the thread below.
Contest Questions:
  • Not important. Sound is what matters.
  • Not important. My surround speakers are on the other side of the room so it doesn’t really matter if they all match or not.
  • Not important. My subwoofer doesn’t match anyway.
  • Somewhat important. I would like to get a matching set, but what works best for my theater/space is of most importance.
  • Very important, if they don’t match the other speakers I’d rather not use surrounds.
  • Other (Please explain)
  • Wall mounted (Concealed wires)
  • Wall mounted (Wire under carpet or baseboards)
  • Speaker Stands
  • Bookshelf or end tables
  • I don’t have surround speakers because (Please explain)
  • Yes, a wireless surround speaker would be great.
  • Yes, I have a difficult room that doesn’t allow me to conceal the wires.
  • Yes, but only if I could find wireless surrounds that matched my current speakers.
  • No, I don’t trust wireless quality yet.
  • No, I have outlets all over the place.
  • No, wireless surrounds are the only solution for my room because I can’t get speaker wire there.
  • Yes, I want a clean custom installed look, the power cords would be a deal breaker.
  • Other (Please explain)Wireless power would be a definite plus, but power cords are less obtrusive than the speaker wires
  • Internal Power Supply, so it has an AC Power cord only.
  • Inline Power adapter such as Power Brick or Wall Wart with thin DC power cord going to the speaker.
  • Doesn’t matter
  • Please explain
  • Shape/design of the speaker
  • The finish/color of the speaker
  • The sound
Note this contest ends on March 31st, 2010. Winners will be drawn shortly thereafter.
Have fun and good luck!
I BOLDED and italicized my responses
F
FLMike
Response
1. Wall mounted (Concealed wires)
5. other--I would want to hear them to confirm sound quality and would have to evaluate the look of them as well. Not a perfect match is fine, but they have to fit in.
3. Yes, I want a clean custom installed look, the power cords would be a deal breaker. Also, tying up two outlets would be an issue.
5. Other (Please explain)--Sound and finish/color are equally important
Gaigebacca
Gaigebacca
In-ceiling mount surrounds
The sound
Trezl
1 - d - Somewhat important. I would like to get a matching set, but what works best for my theater/space is of most importance.
2 - d - Bookshelf or end tables
3 - a - Yes, a wireless surround speaker would be great.
4 - a - No, I have outlets all over the place.
5 - c - Doesn't matter
6 - d - The sound
K
kli
Ceiling Mounted, aimed down at the viewing/listening area, concealed wires.
I would definitely consider it to upgrade my 5.1 to a 7.1 system if they were reliable and had great sound.
It could be possible to utilize this still, if they were mounted on stands behind my sofa (which is in front of the window), although not the most ideal look.
The sound​
N
nole831
# Wall mounted (Wire under carpet or baseboards)
# No, I don’t trust wireless quality yet.
# No, I have outlets all over the place.
# Internal Power Supply, so it has an AC Power cord only.
# The sound
F
Funboy
Contest Questions:
2. Wall mounted (Wire under carpet or baseboards)
4. No, I don’t trust wireless quality yet.
Status
