Enter to Win: Wireless Subwoofer from Aperion Audio!
Status
Not open for further replies.
Y
yepimonfire
1. How important is it to you to match the look of the surround sound speakers with the front speakers in a 5.1 or 7.1 system?
4. Somewhat important. I would like to get a matching set, but what works best for my theater/space is of most importance.
2. Currently, if you have surround speakers where are they located? If don’t have surrounds, why not?
4. Bookshelf or end tables
3. If there was a high quality wireless surround sound speaker available would you consider it for a home theater system?
4. No, I don’t trust wireless quality yet.
4. Wireless speakers have the amplifiers built in and so they need to be plugged into the wall for power. Would this limit you from considering wireless surrounds?
3. Yes, I want a clean custom installed look, the power cords would be a deal breaker.
5. When you buy audio electronics, some products use an inline power adapter (“Power Brick”/”Wall Wart”). If you are considering a wireless speaker for surrounds and where you’d place them, which would you prefer? (Please choose one)
1. Internal Power Supply, so it has an AC Power cord only.
6. If you were looking for a surround speaker to match your existing front speakers but had to buy another brand, what features would be the most important to you?
4. The sound
G
godan
1. Yes, a wireless surround speaker would be great.
1. No, I have outlets all over the place.
4. The sound
zhimbo
zhimbo
To be eligible to win, you must: 1) Be a registered Audioholics forum member, 2) Have USA Residence and 3) Answer the following questions in the thread below.
Contest Questions:
Not important. My surround speakers are on the other side of the room so it doesn’t really matter if they all match or not.
I don’t have surround speakers because
still building system & may move in near future
No, I have outlets all over the place. (BUT may move soon...)
Doesn’t matter
The sound
gregt16g
gregt16g
d.Somewhat important. I would like to get a matching set, but what works best for my theater/space is of most importance.
e.I don’t have surround speakers because (Please explain) Saving $$ to buy the set I want rather than settle for cheaper speakers
a.Yes, a wireless surround speaker would be great.
c.Yes, I want a clean custom installed look, the power cords would be a deal breaker.
a.Internal Power Supply, so it has an AC Power cord only.
a.Shape/design of the speaker
b.The size of the speaker
c.The finish/color of the speaker
d.The sound
e.Other: A through D would all be importent with the emphasis on D
JerryLove
JerryLove
c.Speaker Stands
d.The sound
JoshK
*Somewhat important. I would like to get a matching set, but what works best for my theater/space is of most importance.
* Speaker Stands
* Yes, a wireless surround speaker would be great.
* No, I have outlets all over the place.
* Doesn’t matter
* The sound
Jack Hammer
Jack Hammer
D. Somewhat important. I would like to get a matching set, but what works best for my theater/space is of most importance.
A. Wall mounted (Concealed wires)​
D. No, I don’t trust wireless quality yet.​
A. No, I have outlets all over the place.​
A. Internal Power Supply, so it has an AC Power cord only.​
D. The sound​
bellevegasj
Contest Questions:
  • Not important. Sound is what matters.
  • Not important. My surround speakers are on the other side of the room so it doesn’t really matter if they all match or not.
  • Not important. My subwoofer doesn’t match anyway.
  • Somewhat important. I would like to get a matching set, but what works best for my theater/space is of most importance.
  • Very important, if they don’t match the other speakers I’d rather not use surrounds.
  • Other (Please explain)
  • Wall mounted (Concealed wires)
  • Wall mounted (Wire under carpet or baseboards)
  • Speaker Stands
  • Bookshelf or end tables
  • I don’t have surround speakers because (I'm still putting my first HT together.)
  • Yes, a wireless surround speaker would be great.
  • Yes, I have a difficult room that doesn’t allow me to conceal the wires.
  • Yes, but only if I could find wireless surrounds that matched my current speakers.
  • No, I don’t trust wireless quality yet.
  • No, I have outlets all over the place.
  • No, wireless surrounds are the only solution for my room because I can’t get speaker wire there.
  • Yes, I want a clean custom installed look, the power cords would be a deal breaker.
  • Internal Power Supply, so it has an AC Power cord only.
  • Inline Power adapter such as Power Brick or Wall Wart with thin DC power cord going to the speaker.
  • Doesn’t matter
  • Please explain
  • Shape/design of the speaker
  • The size of the speaker
  • The finish/color of the speaker
  • The sound
Awesome, thanks.
bandphan
bandphan
Doesn’t matter, depends on the final placement
The sound
jhanley
... 5. Very important, if they don’t match the other speakers I’d rather not use surrounds.
... 1. Wall mounted (Concealed wires)
... 1. Yes, a wireless surround speaker would be great.
... 2. No, wireless surrounds are the only solution for my room because I can’t get speaker wire there.
... 2. Inline Power adapter such as Power Brick or Wall Wart with thin DC power cord going to the speaker.
... 3. The finish/color of the speaker
BMXTRIX
BMXTRIX
E - There is no doubt that a theater environment is a part of my home and just like I would try to avoid clashing furniture, I would like to match the speakers in look if possible. Yet, not at the cost of sound quality, and if one manufacturer can't deliver, or gouges on pricing, then I will go elsewhere. For the price and sound quality that I want.
  • Speaker Stands
  • I don’t have surround speakers because (Please explain)
B - I have my surrounds wall mounted with wiring in the walls. Adding a second surround setup to my home with in-wall wiring as well.
E - Bottom line is sound quality and the room the speakers are for. I would not really like a wireless surround solution to be incorporated with speakers, but to be it's own product which can incorporate with any speakers and with any receiver. So, it would need to take the speaker level output found on (basically) every standard receiver and then wirelessly send it to some receiver/amplifier at the back of the room which can be connected to any speakers wanted. Yes, an integrated speaker/amplifier would be nice as well, or better yet, an option for a series of speakers to add wireless capabilities. But, if I could add wireless to any speakers of my choosing, that would be a great option. I deal with difficult rooms constantly where people don't want their walls opened and want surround sound with no wires.
B - Kind of a continuation from above, and not really applicable to my situation, but if someone doesn't want speaker wires from the front to the back of the room, then the only way to go is with a power cord plugged in. But, every room is different and plugs aren't always readily available.
  • Doesn’t matter
  • Please explain
D - I would like an internal power supply with a power cord which is rated to be run IN WALL! This way the speaker could be wall mounted (potentially) and the wire run in-wall down to an outlet near the floor level. I actually could live with an external power supply if the wiring could still be run in wall. The key is that a wall mounted surround can typically easily have a wire dropped straight down the inside of most walls which can really clean the look up.
  • The sound
D - C - A - B
This isn't really multiple choice as all those factors really do apply. A huge ugly speaker isn't going to work, but a lousy sounding speaker is NEVER going in. So, something that sounds good, has a decent finish (no bright orange), a size which is appropriate along with a design that isn't hideous. But, sound is king.
G
gholt
Contest Questions:
a.Not important. Sound is what matters.
c.Speaker Stands
a.No, I have outlets all over the place.
d.The sound
Thanks for your consideration.
tcarcio
The sound
Moutee
Moutee
Speaker Stands
The sound
blownrx7
blownrx7
The sound
ParadigmDawg
ParadigmDawg
1. Not important. Sound is what matters.
In-celing
3. Doesn’t matter
4. The sound
theJay
2. Not important. My surround speakers are on the other side of the room so it doesn’t really matter if they all match or not.
3. Not important. My subwoofer doesn’t match anyway.
6. Other (Please explain)
2. Wall mounted (Wire under carpet or baseboards)
3. Speaker Stands
5. I don’t have surround speakers because (Please explain)
2. Yes, I have a difficult room that doesn’t allow me to conceal the wires.
3. Yes, but only if I could find wireless surrounds that matched my current speakers.
5. Other (Please explain)
4. Other (Please explain)
3. Doesn’t matter
4. Please explain
1. Shape/design of the speaker
2. The size of the speaker
4. The sound
BoredSysAdmin
BoredSysAdmin
Speaker Stands
Doesn't matter
The sound
trnqk7
[*]Somewhat important. I would like to get a matching set, but what works best for my theater/space is of most importance.
[*]Wall mounted (Concealed wires)
[*]Yes, a wireless surround speaker would be great.
[*]No, I have outlets all over the place.
[*]Internal Power Supply, so it has an AC Power cord only.
[*]The finish/color of the speaker
[*]The sound
MidnightSensi
MidnightSensi
Not important.
I have bracket wall mounted rears with concealed wires (through the wall).
  • Yes, I've considered going wireless for going from 5.1 to 7.1. I can't run speaker wire to the sides, because of glass and concrete. I do, however, have an outlet on either side.
    The sound
Status
