That’s a great chart, PENG!
So if you own the A860 pre-production model (1Vrms) and you own an amp with 32dB Gain, you could output 200W, not that you want to do that.
But if you have a 26dB amp, the 1Vrms gets you 50W.
Do you know what the preamp output voltage of the Yamaha A1080 (any 1000 series or higher) is?
You've got it! By the way, are we sure the one Gene reviewed was a pre-production model? Note that Gene's review was done on Feb 22 2017, the RX-A860 was a 2016 model so by Feb 2017 it would have been out for at last one year.
Also, please note Gene's comments below, his 2017 review:
The power supply is a bit smaller than I've come to expect in AV receivers in this price class. As comparison, the power supply in my friend's $400 Yamaha RX-V659 AV receiver that just lost a battle against a lightning storm is a bit bigger with a larger IE core transformer and more generous capacitor bank (71V 12,000uF Caps x 2) compared to the much more expensive RX-A860 (71V 8,200uF Caps x 2).
Just look at the pictures and you can see the corner cutting.
About the pre out voltage, below is what I found on the schematic diagram of the RX-A1050 (2016 model):
typ: 1Vrms (Vol +16.5 dB)
I hope that was a typo, otherwise it is disturbing as you might have guessed, that +16.5 for Yamaha AVRs is the maximum!! That would seem somewhat consistent with Gene's finding.
I am with
@KEW, on his keen observations on the 860, and again, until I see some bench tests of the RX-A800 and 1000 series, I would have to assume it is saver to go with the 2000/3000 series if matching power amps is a concern, though the RX-A1000 series may still be fine if that 1Vrms thing was in fact a typo.
The RX-A860 should have no trouble matching
some of the Emo amp that are rated 32 dB gain.
