Stevenn ... I knew you love more than infra-sonic bass - but messing with you is too hard to pass up ...
RMK! - As things progress, look for the DD-18 and the EP-500 to be tossed into the mix.
NOW .. for John E. Johnson's review. Mr. Johnson is truly one of the pioneers in the reviewing industry... He has published Secrets for 11 + years now, and has earned the respect of those who really know the man.
His subwoofer reviews are a bit different than what Ed M., and those who are copying his style, use. This does not make his review any less worthy.
JJ takes the time to audition each subwoofer first, then he takes the measurements. His listening tests are excellent, but let's look at his measurements, and see how useful they are.
Three relatively recent review from JJ include the VTF-3HO, the Sunfire Signature, and the Earthquake 15-MKV.
The Sunfire lists for $2200 ... street price of $1800.
The Earthquake lists for $2799 ... street price of $1600.
The VTF-3HO has a permanent, $899 price sans turbo.
All three subs have fairly comparable THD levels at 100 dB. A newer test which JJ has added is a pretty solid indicator of a subwoofer's ability. HE only uses this test on subs with a substantial 20 Hz output - for example, he left this test out of a recent review of the Velo DLS-5000R, as it does not have a solid 20 Hz output.
This test he is using replicates what happens to a subwoofer in the real world. When we are watching a movie with good bass, the bass scenes tend to have a large mixture of different frequencies. JJ's new test places a high level signal consisting of equal parts 20, 31.5, and 50 Hz bass.
He then measures max output for each sub with the three "hitting" simultaneously.
Here are the results for the subs mentioned ...
The Sunfire ...
Maximum output, using a combination of 20 Hz, 31.5 Hz, and 50 Hz, was 110 dB. Putting the subwoofer in a corner would add a few more dB, bringing it in right about at the manufacturer specification of 116 dB.
The Earthquake ...
I was able to achieve a maximum SPL of 120 dB at 1 meter, using a combination of 20 Hz, 31.5 Hz, and 50 Hz sine waves.
The VTF-3HO ...
Using a combination test tone consisting of 20 Hz, 31.5 Hz, and 50 Hz, I was able to get a maximum output SPL of 116 dB without the Turbo, and 115 dB with the Turbo, at 1 meter
Let's compare them ...
Sunfire - 110 dB for $1800
Hsu - 116 dB for $900
Earthquake - 120 dB for $1600
I encourage people to take the time and to visit the full reviews all three subs tested by JJ, and look at the graphs, look at these numbers, and see what you learn.
For now, I can assure you the numbers as posted above are a VERY good indicator of each unit's capabilities.
