Why I am not getting the full UtraHD audio from AmazonMusic
Epsonfan
Epsonfan
My setup as follows Sony A90J 65 inch receiver is Marantz SR6015 using eArc [HDMI] I am streaming from Google App/Sony the Amazon Music App & I am getting this
The track quality : 24-bit/192KHZ
Device Capability : 16-bit/48KHZ
Currently Playing at : 16-bit/48 KHZ
Codec: FLAC
Why I am not getting the full 24-bit/192 KHZ . Is there a setting on the Marantz that needs to change or I am at my limit in my devices ?..
Epsonfan
Epsonfan
thanks i was at amazon website before posting I am still in the dark . What the hell is Alexa
Pogre
Pogre
Codec: FLAC
I had to go into my sound settings on my pc and click 24/192 in a drop down box.
Pogre
Pogre
On Windows 10 for pc I right click on the speaker/volume icon in the bottom right corner.
Click "open sound settings"
Click "sound control panel" on the right
Click on your receiver in the window that pops up
Click "properties"
Click "advanced" in the next window that pops up
You will see a drop down where you can pick higher resolutions.
Sometimes that setting randomly reverts back to default and I have to go in and change it again.
*Edit: don't forget to click "apply" where you see it before closing the windows out.
Epsonfan
Epsonfan
Wait PC ... I am streaming from Amazon Music through Google App via Sony A90J TV to Marantz receiver no PC here
Pogre
Pogre
Well then I am usless, lol.
Now that I think about it, I also have a firetv (android) and it won't play the higher resolutions either. I can only get it with my pc.
cpp
cpp
In order to take advantage of Amazon Ultra HD hi-res quality (lossless 24-bit/192kHz resolution), your device must support it which your 6015 does. Maybe its just a option not set correctly either in Amazon or your AVR,. Just a thought,
Epsonfan
Epsonfan
thanks for trying I can live with 16 -bit & 48 KHZ for now
Epsonfan
Epsonfan
According to Amazon Marantz supports Utra HD
Pogre
Pogre
If it's any consolation, I couldn't hear any difference between 16/48 and 24/192 on Amazon. I can hear the difference between Amazon HD and regular Amazon tho. There is an improvement. Almost as good as my cd rips. Almost. It's close but cd (and lossless cd rips) still sound just slightly better.
Pogre
Pogre
The Marantz does, but your streaming device might not, or there may be a setting you have to change on it. I know my firetv is what it is, and that's 16/48 at best.
Pogre
Pogre
I didn't have to change anything in my receiver (Marantz SR6011). Just the settings on my pc. The Marantz seemed to automatically decode it.
Trebdp83
Capable receivers matter not if device used for streaming is limited by hardware or is not supported by service. When choosing a service, one needs to check for devices that support everything that service has to offer or deal with limitations from devices not in the service eco system. Even then, issues arise. TV's aren't the best place to look for apps that support services to their full potential. You may get two good apps to go with the rest of the crappy ones. Say, doesn't Marantz' HEOS app support 24/192 from Amazon Music Ultra HD? Try using it instead of the TV app.
Hetfield
I get Amazon music HD up to 192 from my Fire Cube and Denon X3400HD. It does sound great and the HD part is free now.
Epsonfan
Epsonfan
thats a good idea
Pogre
Pogre
Wait, what? Free now? I haven't checked Amazon HD in a while, since I had a free trial and stopped when it ran out. I may have to revisit. Amazon's HD is actually pretty good. Not quite cd quality, but pretty damned close. Close enough it could have been a difference in gain that I heard.
Hetfield
It's free if you sub to music unlimited. Yup, very cool. I was paying for it and then I got an email is free going forward.
