You ask for information from me to support my claim but in your previous post you submit none,same with this post,zero info to back up your claims
Your math is wrong.
15 Amp service = 1,800 watts X amplifier efficiency = max wattage .
20 Amp service = 2,400 watts X amplifier efficiency = max wattage .
Assuming 40% efficiency from the amplifier, which is on the low end of efficiency, a standard 15 amp service will be capable of running 800 watts,a 20 amp service would be able to produce 960 watts in an amplifier that is 40%efficient,these figures represent a single channel not stereo.
As for not ever seeing or hearing speakers that will take a full 200 watts there are none ive ever seen that will take it but we both know there are a ton of speakers that will use a full 200 watts,with the majority of wattage being converted into motion & heat.
I showed you mine now show me yours.
