Stevor
I have an old Pioneer Elite DV 38A DVD-A player that has no HDMI output for the OSD, thankful they still have one or some.I can’t understand why they still put component video connectors on AVRs.![]()
Well 1080p is the highest resolution possible on component video cables.Here this will explain it better than I could do in short term.
HDMI Versus Component Video -- Which is Better?
www.bluejeanscable.com
DVD-A and SACD are cool. I do play them over HDMI on my Sony X800 but not every UHD player can play those formats.I have an old Pioneer Elite DV 38A DVD-A player that has no HDMI output for the OSD, thankful they still have one or some.
I have a bunch along with an ever growing library of BluRay Audio discs I pick up as soon as they are available. They always seem to be very limited runs and I love 5.1, generally but have a dedicated 2.1 channel system as well.DVD-A and SACD are cool. I do play them over HDMI on my Sony X800 but not every UHD player can play those formats.
rg6qs can produce a high resolution analog format . It can send more data than cat.5 or cat 6 in an analog form. Most people don't understand what they're talking about or just misinformed. One reason why they won't use an analog medium for 4K is because they can not encode anti-piracy protection such as hdcp. Since HDMI sends data in a binary form, they can encrypt their material and have more control over copy right protection. And rg6qs in analog (waveform) ( same as rgb, per say except not quad shielded), making it difficult if not impossible to encode (encrypt) the signal. So copyright protection goes down the drain, can't have that can weWell 1080p is the highest resolution possible on component video cables.
Interesting. Well if I’m buying a disc, it’s usually going to be 4K UHD HDR.rg6qs can produce a high resolution analog format . It can send more data than cat.5 or cat 6 in an analog form. Most people don't understand what they're talking about or just misinformed. One reason why they won't use an analog medium for 4K is because they can not encode anti-piracy protection such as hdcp. Since HDMI sends data in a binary form, they can encrypt their material and have more control over copy right protection. And rg6qs in analog (waveform) ( same as rgb, per say except not quad shielded), making it difficult if not impossible to encode (encrypt) the signal. So copyright protection goes down the drain, can't have that can we.
Agreed, and they don't give us much choice now a days. Digital has great benefits, but so does analog. But I think there could be reasons why they are trying to wipe analog out. Encryption being the number one factor.Interesting. Well if I’m buying a disc, it’s usually going to be 4K UHD HDR.
The new Yamaha 3000-series will sound just as awesome as your good old 3000-series, except even better because of Atmos, DTSX, DSU, and NeuralX.Hi Audioholics.
Well it's about time to upgrade from my Yamaha rxv3800b, (my baby).
I've had her for nearly 15 years and I think I have her sounding really nice, I've put in a lot of work over the years and learned a lot.
I'm worried that I may not be able to expect much improvement regardless of how much I spend on a receiver. I'm hoping someone here can ease my fears. I will particularly miss the beautiful Yamaha orange of my display, I don't much like the blue colours but I can live with it.
I'm using REW and have SVS ultras.
It sounds really nice.
Am I approaching a point of diminishing returns?
Thanks guys
.Op, unless I missed it, I didn't see what your budget was or is I should say. Some have recommended the denon 3500, however if budget permits I would at least step up to the 3600. I know some wont quiver about the 3500, but I wouldn't take it even if it were for free. Heat sinks are a joke and placement of the power transformer looks awful to. At least the 3600 appears to have decent heat sinks and the transformer has been repositioned properly.
Some people are going to jump in and say , oh it doesn't matter. But it does. Electrical components are inherently noisy, and the quality of those components and there placement makes a difference. Looking at the 3600 makes you think they caught the mistakes on the 3500 and addressed them correctly on the 3600.Take a look for yourself and you be the judge.
The 3500 is a 7.2 AVR and the 3600 is a 9.2 AVR. You will note that not only did the 3600 use different heat sinks, but it also adds a built-in fan!Thats very interresting, didnt know they were very different inside, they usually arent. So much around the forums about the 3x00 line and first time big internal differences are mentioned and i wholeheartedly agree that placement and heatsinks matter a lot. Whats the best for each to buy i guess depends on how big a price difference there is.
If you use external amplification, you can run the Denon (either model) in ECO mode and that will drop the temperature of the AVR by roughly 10 degrees F!.
I'm willing to be very generous with my budget.
Spend it well spend it once. I am coming to see that a denon avrx3600h would do and spend good money on a nice power amp. It is a shame that a nice receiver worth solid money becomes worthless after a too short time just from technology obsolescence but it is what it is I suppose
I agree a better layout is a better layout, but it was suggested that you can hear the difference and I disagree with that part of the statement. I haven't read any accounts of the 3500 running hot or experiencing problems due to heat. Bang for buck It's gonna be hard to beat that price right now.
Pogre, brother I think you may have misread what I said originally. or I did not state it clearly . I stated my thoughts and concerns about the transformer placement and the ridiculous heat sink ( those on the 3500 look like the ones used on those cheap low end pro amps that people complain about over heating and burning out ) I never made the claim you would be able to hear a difference between the 3500 and 3600,. I had said that electrical (electronic) components by themselves are inherently noisy. Which is why the components and layout make a difference in the end. And why some manufactures will use better components in their higher tier over lower tier models.The 3500 is a 7.2 AVR and the 3600 is a 9.2 AVR. You will note that not only did the 3600 use different heat sinks, but it also adds a built-in fan!
I would not be too quick to recommend one over the other without more info (unless you really need the extra 2 channels!). The 3500 was packed and I could see how they would have to go to extremes to accommodate the additional heat of 2 more amps. In this era, when AVR's are designed with a lifespan of 8 to 10 years, you don't have the luxury of believing better heat sinks will buy you another decade of service.
If you want th best for what you are willing to spend, it really seems like the next big update will be to HDMI spec in the 2020 release cycle... so maybe if you can play the long game and wait 2 years, you get the discounted price starting Summer 2021 for something that then should easily (*knocks on wood) cover several years of upcoming releases..
Man doesn't seem like that long ago when 5.1 was the oh wow. Now were talking 16 channels. Cant imagine what will come after that.If you want th best for what you are willing to spend, it really seems like the next big update will be to HDMI spec in the 2020 release cycle... so maybe if you can play the long game and wait 2 years, you get the discounted price starting Summer 2021 for something that then should easily (*knocks on wood) cover several years of upcoming releases.
I have accepted this as my path... new HDMI protocol as well as stabilization to the multi-channel receiver market. *fingers crossed
It will, of course, not be this simple. However, in my mind: I will be able to get a 16-channel AVR with a seven channel, fully assignable amp, Dirac Live with Bass Management Module, and a Rootbeer Lollipop. All for $1995, MSRP. Marked down to $1249 the following summer!
C'mon, Truth...Man doesn't seem like that long ago when 5.1 was the oh wow. Now were talking 16 channels. Cant imagine what will come after that.
Watch out, don't fu… with Telly, You know he loves you baby.
Game represent game... I'm old enough... barely... but I remember.Watch out, don't fu… with Telly, You know he loves you baby.![]()
