WmAx
WmAx
zumbo said:
The "pro gear" seems to cost less.
Ex: Crown, Ashley, Behringer.
Right, and that's what I meant by "if cost is an issue". If cost is not an issue, you can obtain similar performance to the pro-gear, but at much higher prices, using hi-end gear. The only benefits that hi-end gear brings to the table so far as I can tell are: cosmetics, bragging rights and pride of ownership.
-Chris
jeffsg4mac
jeffsg4mac
Republican Poster Boy
Yes it does, why is that I wonder? I always thought pro amps would only sound good for sound reinforcement and guitars and such. That does not seem to be the case. Some pro amps look awesome for the money. Are they just priced fairly and home audio is not? I would not be surprised at all if that is the truth.
Z
zumbo
-Chris
http://www.proaudiosuperstore.com/Ashly-MFA8000.html
jeffsg4mac
jeffsg4mac
I do know that pro amps used to be different designs than most home audio amps. Class H and such instead of class A or B or A/B. Is that still true?
Z
zumbo
The Ashly stuff is class A.
WmAx
WmAx
Depends on the specific model. Most pro amps are switching amplifiers(Class D, H, T, etc.). But modern well-designed switching amplifiers perform perfectly. Some pro amps(such A500) are class AB, just like most hi-fi amplifiers.
-Chris
WmAx
WmAx
Which Ashly stuff is class A? Class is the most inefficient class of operation. No way could Ashly compete in the business if they had to implement thermal dissapation and power supplies that are several times the capacity as required by other operation classes.
-Chris
jeffsg4mac
jeffsg4mac
-Chris
Hmmm, that A500 seems like the answer to my needs or wants anyway. The drivers I was considering are 4 ohms so in series they will be 8. The A500 will do 500 watts mono into 8 ohms. More than enough to drive dual 10's and only 179.95. American musical will let you spread those payments out over 3 months:) 139.00 for each for 4 drivers, and about 100 bucks each for finished boxes that I build. Grand total of 1114.00 for two subs flat to 18 or lower.
WmAx
WmAx
Optimistic specifications on Behringer's behalf. Actually it's 360 watts @ 8 ohm bridged with no clipping, or 440 watts bridged @ 8 ohms, at 1% THD.
-Chris
MacManNM
MacManNM
zumbo said:
Yes. I have the Adcom. Jamming some Days of the New at the moment. I was not planning on changing my current set-up, but was beginning research for a 2-channel(music only) system. Then that Butler amp was listed on another thread. So, after all the goo goo I have seen and heard about tubes, I wondered if my current 5.1 should evolve, instead of a seperate 2-channel system. Anyway, I dream of some B&W 801's powered by something.
Well there is something to be said about listening to some nice music in the dark with the warm glow of tubes. I don't know if I would use 801's though.
Here is tthe perfect tube setup IMO
http://cgi.ebay.com/Klipsch-Heresy-II-Speakers-Sequenced-Pair-Match_W0QQitemZ5848894330QQcategoryZ61378QQrdZ1QQcmdZViewItem
Or
http://www11.plala.or.jp/se_ke5583/JBL/speaker/l101lancer.html
Then you need a couple of these:
http://cgi.ebay.com/2-MCINTOSH-MC60-MONO-TUBE-AMPS-CONSECUTIVE-SERIAL-NOS_W0QQitemZ5847024632QQcategoryZ73371QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Finally one of these:
http://cgi.ebay.com/McIntosh-C-11-Stereo-Tube-Preamplifier_W0QQitemZ5848390122QQcategoryZ67807QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Now that is a tube system!
jeffsg4mac
jeffsg4mac
-Chris
Still plenty for a sub, and probably much better then a so called sub amp designed to mount in the back of a sub. Bash, etc.
Z
zumbo
WmAx said:
I promise you, not one of those features a class A output power amplifier section. From their descriptions, they refer to class A 'driver' and 'front end'. That just means the line level input buffer is class A. Not the power amplifier section. Realize, that a class A amplifier is 25% efficient.
-Chris
They say
The MFA-Series utilize the latest design parameters for Mos-Fet power devices. All power and gain stages use discrete, full complimentary, class-A circuitry for very low distortion and clean overload behavior.
I am not educated on amp "class", so pardon my ignorance. Learning.:)
WmAx
WmAx
zumbo said:
They say
Then that is a typo or they lie. It's not physically possible for their MFA-Series amps to deliver their rated power if they are Class A. In fact, the MFA-Series must be switching amplifiers to deliver their rated power output(and the MFA-800 would have to be driven by a 240VAC line even then, to produce it's rated 2 ohm output capability).
-Chris
Z
zumbo
-Chris
Why would a respected high-end pro-gear company lie about their specs? This isn't Bose.
http://www.ashly.com/
http://groups.msn.com/barley/frontdiffoilseals.msnw
WmAx
WmAx
I don't care to speculate on the typos or lies(which ever they may be).
Zumbo, here are some basic physical rules....
I(current in amperes)*V(voltage)=P(power, in watts).
A standard home line is 120V*15 amps = 1800 watts. The heaviest capacity 120V line allowable by elecrical code is 120V*20 amps = 2400 watts.
Each amplifier class has a typical efficiency approximation. A percent of the total power that it can turn into output power. Here is a breakdown:
Switching Amplifiers:85%-95%
Class AB: 50%
Class A: 25%
To get the rated 2 x 800 watts @ 8 ohms of the Ashly MFA-800 claims, if it was class A output stages, it would have to consume 6400 watts. Not possible from a 120VAC line. But that is only the beginning of the consideration. A Class A amplifier also produces far more heat than any other class, and it(unlike other classes which only disapate in proportion to the power being actually output from the amplifer) disappates the full wasted percent of energy 100% of the time. So that means you have a 4800 watt space heater in case of the MFA-800. The heatsink/cooling solution would not even fit in the case size of the MFA-800, and the power supply alone would be as big as the entire case. In fact, in AB operation, it could not produce 800 x 2 from a 120VAC house line. It must be a switching amplifier to reach even this spec with continous power output.
-Chris
EDIT: Corrected number of channels of MFA-800.
Z
zumbo
Class AB: 50%
Class A: 25%
To get the rated 800 watts @ 8 ohms of the Ashly MFA-800 claims, if it was class A output stages, it would have to consume 3200 watts. Not possible from a 120VAC line. But that is only the beginning of the consideration. A Class A amplifier also produces far more heat than any other class, and it(unlike other classes which only disapate in proportion to the power being actually output from the amplifer) disappates the full wasted percent of energy 100% of the time. So that means you have a 2400 watt space heater in case of the MFA-800. The heatsink/cooling solution would not even fit in the case size of the MFA-800, and the power supply alone would be as big as the entire case.
-Chris
So, are you saying AB is the way to go?
WmAx
WmAx
I am not endorsing a particular class of operation. Today, you can find good examples of any class of operation.
-Chris
Rip Van Woofer
Rip Van Woofer
I am shocked...yes, shocked!...that no one, not even Chris, mentioned one of the most compelling advantages of tube amps:
They do double duty as space heaters! Maybe even as hot plates. I have heard that you could fry an egg atop a Pass Aleph. Just the thing when you're in the doghouse with the Mrs...
