Swerd
The maple Phil 3s you saw are Dennis's speakers. He uses them to demo his designs to potential buyers, and has dragged them to some audio shows. They were built sometime before July 2011 and were the first Phil 3 cabinets.I wonder why and how the angle got built into Kurt's cabinets. I only noticed when they were side by side with the Maple pair. That makes for a tougher build but it does look good. Very sphinx like the way they're leaned back with that grain orientation.
Kurt's Phil 3s show the various changes, mainly cosmetic, including the angled sides vs. straight sides that you noted, and the chamfered edges vs. rounded-over edges. If I recall, the angled sides were done to make the cabinets look like they intrude into the room a bit less. And yes, that made them more difficult to make.
Unless there is a clearly audible or measurable difference, it doesn't matter what any engineer said. You mentioned measurements done by AH. Do you know where they are?Peel-N-Seal does deaden the cabinet more, but I'm not sure it's not because of the added mass. I discussed this at length with a mechanical engineer who works with CLD and he thought it was the mass that really made a difference in the speaker. We've seen measurements done by AH on this so it certainly does have an effect. I'm not sure it's worth the extra effort and I'd never use it in a commercial design. If I ever finish my speakers I'll tell you how it sounds. This weekend is promising temp wise and rain wise. Though I need to recut my baffles and I'm really not looking forward to it. Finishing will be a pain and I'm seriously considering getting a pro to do that.
You, of course, are free to do whatever you want on your own speakers. But to recommend such modifications to others requires (in my opinion) good evidence of an audible improvement.
