daxriggs - I stand corrected. It was hard to see from the picture. The Pendragons use an SB Acoustics SB29RDNC tweeters and NOT the Vifa XT25.
With the SB Acoustics tweeter, one can get away without an LCR network and cross the tweeter as low as 1.6kHz using LR4.
This tweeter can actually be crossed over as low as 1.1kHz using LR6
Take a look at some of these rather excellent designs:
Zaph|Audio - Design Contest Results
If in the Pendragons the tweeter is crossed this low (1.1kHz - 1.35kHz), using three tweeters can actually lower distortion. The high frequencies would have to be carefully rolled off on two of them in order to minimize the combing effect.
Further information: A 10" woofer begins to beam at 1350Hz. From Zaph's data, we can clearly see that the SB Acoustics SB29 tweeters can definitely be crossed over this low with a steep enough slope, LR6.
I will stand corrected again. It is possible to build a speaker with these SB tweeters and these 10" Eminence woofers and still have a good power response.
So here's my question: Are we certain that these Pendragons don't have a crossover on the woofers? No crossover = major cone break-up and this whole project becomes nonsense. But what if they do use a crossover?
With a proper crossover on the woofer, this might be a rather interesting and high sensitivity design
 I'm mildly interested... Bottom line, I could build a good measuring and sounding speaker using these drivers and layout, but weather Tekton knew what they were doing remains to be seen. I would have to measure one of these speakers myself, or see some comprehensive measurements by the NRC, or Stereophile.
P.S. Looking at some of the other speakers in their line, I could be giving them more credit than they deserve
