subwoofer ideas for a desktop
Dude#1279435
Small. Maybe the JBL "creature", but a little too creature-y for me hahaha. Any ideas?
Had to look up the JBL thing....never saw that before. I wouldn't call that a sub either....bass module maybe. How small do you need?
Dude#1279435
My desk is about 6 long x 3 deep. I certainly can go larger, but I don't see the point since it would be sitting so close to my ears. I have 305s. Give me advice on what you think would work please.
Where does the sub need to go, tho and what are the max dimensions?
stalag2005
I am using a SB3000 under my desk. It is paired well with the Martin Logan LX-16 bookshelf speakers that sit on my desk.
ryanosaur
ryanosaur
Just some ideas.
Other 2000 series subs are on sale at SVS. (Not the newer Pro models.)
I think I saw that the Monolith 10" is on sale right now, too.
Dude#1279435
Just some ideas.
Those are going to be too much $$$ for my needs. The 200 watt Monoprice above is probably the best bang for the buck. A Dayton, or the 8 inch Mono at Target for $75. Thank you though.
ryanosaur
ryanosaur
Depending on what you expect from this Sub, you should pay very close attention to the specs.
That 8” Monoprice has a limited extension to only 50Hz. Bass Guitar hits about 40Hz, Piano 29Hz.
Granted, at $75 it’s supremely affordable, but that doesn’t make it a bargain. ;)
Dude#1279435
Look like the Dayton 12 or 15" fits the bill. They go down to 23 or 25hz.
ryanosaur
ryanosaur
The Dayton Sub1200 is one of the best options, I think, for a budget Sub. In fact, the performance between the 12 and the 15 stacks in favor of the 1200.
It is limited on the high end, to 150 Hz, iirc, which is possibly the only real drawback if you need to transition from small desktop speakers.
Of course, that is the point in shopping where you have to weigh the tradeoffs. ;)
Dude#1279435
JBL Subwoofer
ES150P SPECIFICATIONS
Amplifier Power (RMS): 300 Watts
Peak Dynamic Power: 500 Watts
Driver: 10” (254mm) PolyPlas(TM)
Inputs: Line Level (switchable to LFE)
Low-Pass Frequency: Variable from 50Hz to 150Hz (24dB/octave, continuously variable)
Frequency Response: 27Hz – Low-pass crossover setting
Dimensions (H x W x D): 18" x 13-1/4" x 15-1/4" (457mm x 337mm x 387mm)
Weight: 39 lb/17.7kg
This might work. Local pick up for $60.
