I'm having a blast going through the menus and tweaking stuff. I did make a pretty dumb mistake already. When I first set the trim on the subs using the subwoofer level adjust under "audio" (not level adjust from the test tones) in the menus. I turned it up to +3 (default is 0) thinking I was adding 3db... Um, nope. I ran Audyssey again and set it properly this time. Audyssey went with -10 and I bumped it to -7 this time instead of +3. There goes all that "extra" bass I was hearing!
Derp.
Now that I'm re-accustomed to proper sub levels it still sounds better and fuller than before. Another thing I'm noticing are the highs. They're more there for sure also. I see that XT32 set the trim higher for frequencies above 8000 hz or so than the X1200W did. Like, by a lot. The 1200 trimmed to negative where the 6011 bumped to the plus side. I'm hearing cymbals a lot better now along with other things I hadn't noticed before. Big improvement there as well. I'm very happy about that.
There's one thing for sure that I don't like. The 6011 is getting hotter than the 1200 did. My normal listening range is about -20 to -30db. Right now I'm home alone so I'm cruising right along at -20. Sounds awesome, but when I place my hand on top it's
really warm. Almost too warm to keep my hand on it. I'm thinking a fan is going to be a necessity.
