Performance!
Setup was super simple. Just plug the included cord into the back of the unit and plug the other end into a wall socket. That light tho...
Does turn off! I had to read the manual to figure it out and it wasn't super clear (at least for me, I'm slipping in my old age.
![Stick Out Tongue :p :p](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
), but I got it figured out.
I like the way it looks and it's plenty quiet. There are 3 different modes- On, Auto and Smart. I went with the latter. It kicks on at a higher speed when it gets up to 88° F, then adjusts down a notch every 2 degrees until it hits 84° and shuts off. I think auto does the same thing without adjusting the fans' speed. You can adjust that (fan speed) also. High makes some noise, but not bad at all from where I sit. 50% is pretty much completely inaudible.
I dig it. Makes me feel good things are running cooler now and I'm (hopefully) adding some life to my receiver. Thanks for the suggestion Kurt!
