I have had heard that salt retards the yeast, good point!. The starter I made today was alive and well after about ten mins, however it was sitting in a very warm environment. I have never tried letting pizza dough rest overnight in the fridge but I have made Brioche before and that is a step you have to take with that recipe. Leaving the Brioche dough in the fridge overnight definetly developed that fluffy and deep yeast flavour to the Brioche.
If you wait on the salt you would probably be able to get away with using 1/2-1/3 teaspoons of active dry yeast which will allow for far more flavor. The refrigeration step retards the dough's development significantly, but this retardation allows for far more complex flavors to form. It isn't a technique that should be used in all doughs, but pizza is a perfect candidate.
Ohh, I also forgot to mention my favorite toppings. Very thinly sliced* mushrooms, button works, but if you can get morels, chantrels or porcinnies they are even better. Cook the pizza and then drizzle some truffle oil on top. This 'tartufo' pizza is everyones favorite pizza after they try it. I have even converted people to mushrooms with it. One note, with a recipe such as this it is imperative that your oven is on its hottest setting and ideally you are using a seasoned pizza stone.
*If you feel your knife skills aren't up to this job use a mandoline or benriner.
My pizza dough recipe
makes 2 pies
1/2 teaspoon active dry yeast
2/3 cups warm water (about 95 degrees)
Mix together and allow yeast time to activate.
1/2 lb King Aurthr's all purpose flour
.15 lb semolina
1 tablespoon olive oil
1 teaspoon fine sea salt
Once yeast has activated add these ingredients and mix 3-5 minutes or until ingredients have come together. Form a tight ball of dough.
Let dough rest for about 45 minutes with a thin coating of olive oil. With slightly wet hands fold dough over 3-5 times like a sheet of paper then form a tight ball. This encourages glutens to form - do not tear the dough as this destroys those glutens. Repeat this process 4 more times. Divide the dough in two pieces and wrap in plastic wrap after forming a tight ball (allow room for the dough to grow in the wrap). Retard in refrigerator overnight.
Heat your oven to its hottest setting with pizza stone in place. Take the dough out and let rest for half an hour. Slowly stretch out the pizza dough (rectangular shapes are the easiest). If the dough is too elastic wait 5-10 minutes and try again! Rushing the process will tear the dough and harm the final result. The skin should be very thin with a slight lip around the edges. I recommend doing this on parchment (not wax) paper. This makes life easy when transferring the dough to and from the oven as you can leave it on this paper and it won't burn, just make sure there are no edges greater than 1.5" sticking out around the pizza crust.
Add about 1.5 tablespoons of sauce recipe that follows per crust and spread evenly (no sauce is used in the tartufo previously discussed). More will result in a wet/soggy pizza. I add a three cheese blend of fresh mozzerella about 3 large rounds placed on the pizza and a mix of shredded Parmesan Reggiano and Pecorino Romano. The mozerrella adds a creamy texture and the parm adds a smooth nutty flavor while the Romano gives some bite. Add any other ingredients, but be sparing - too much will result in a soggy pizza. Place in oven until golden brown and cheese is melty, 10-15 minutes. Wait 3-5 minutes then cut and serve.
Sauce recipe
28 oz high quality ground tomatoes (San Marzano)
1/3 tsp basil
1/3 tsp parsley
1/3 tsp oregano
1 tsp sea salt
1 tsp fresh chopped garlic
Mix everything together and let sit overnight.
I realize this is an incredibly intensive recipe, but don't let it deter you. This will be the best thin crust pizza you have ever had presuming you do everything right
. It is ultra thin, crisp and full of flavor! Also, when I make this recipe I typically multiply the dough recipe 4 times over and ensure there are plenty of leftovers for the week.
