Perlisten S7t Tower Speaker Review
Boerd
For people who seem to debate the excellence of Perlisten S7T please look at this measurement at 89db:
The drivers there are very expensive. At the time the distortion was so low it was called "absurdly low".
The reaction was:
"This is absurdly low. We are talking class-leading performance here. In fact, I don't even think these results are entirely accurate, as I suspect what was recorded was just the distortion in my amplifier as well as background noise. XTZ can pat themselves on the back for a well-engineered speaker in terms of non-linear distortion. "
The S7T has the same distortion level in db - NOT relative db at 96db!!! That is 7db higher output, the same distortion level (again the level dbs not the relative dbs, very important). Just think about it.
S7T is truly spectacular.
Boerd
Did some back of the envelope calculations about the vertical sound dispersion for this speaker.
The tweeter is at 32" = 81.2 ~ 82 cm according to https://www.stereophile.com/content/perlisten-s7t-loudspeaker
The speaker has a 2 degrees tilt - again as per Stereophile.
For the following computations keep in mind the strongest sound is perpendicular on the cabinet (the center of the 30 degrees of dispersion is NOT horizontal but perpendicular on the cabinet).
From the measurements, the directivity is around 15 degrees around the perpendicular to the cabinet (tilted 2 degrees).
tan(15deg + 2deg) = tan(17deg) ~ 0.3
My ear at the couch is about 38" and I sit at 3 meters.
300 * 0.3 = 90cm above the tweeter the signal ends rather abruptly - at 82 + 90 = 172 cm
On the other side (below the tweeter) the window is 15 deg -2 deg = 13 deg.
tan(13 deg) = 0.23
300 * 0.23 = 69 cm below the horizontal of the tweeter => 82-69=13 (just above floor, no reflections for the strongest window of the signal)
This means the window at 3 meters is between 13 cm and to 172 cm .
Given the human ear is (wild guess) 10-15cm below the top of the head and 172 + 15 = 187cm, 6.1 guys can still listen on their feet (at 3m) , laying / sitting on the couch.
The tweeter seemed low for such tightly controlled vertical window. In fact, all is fine.
shadyJ
Speaker of the House
Staff member
From the measurements, the directivity is around 15 degrees around the OX (horizontal) axis.
My ear at the sofa is about 38" and I sit at 3 meters.
tan(13 deg) = 0.23
300 * 0.23 = 69 cm below the horizontal of the tweeter => 82-69=3 (just above floor, no reflections for the strongest window of the signal)
This means the window at 3 meters the main / most powerfull sound window is between 3 cm and to 172 cm .
Given the human ear is (wild guess) 10-15cm off the top of the head:
172 + 15 = 187cm. In other words 6.1 guys can still listen on their feet (at 3m) - or laying on the couch, or sitting on a sofa.
That was a back-of-the-envelope calculation? Must have been a pretty big envelope!
Boerd
Caught red handed.
I read here:
"Don't listen to this speaker while standing."
I respectfully disagree. Envelope or not :)
shadyJ
Staff member
I read here:
Agreed. There is a tonal shift if you are very close to the speaker and stand up, of course, but if you are a few meters away from the speaker, the vertical dispersion will encompass a wide enough angle that the sound will be consistent whether you are standing or sitting.
Boerd
And the beauty of the narrow window is that at 3m there are still no main reflections off the floor. (higher frequencies that is - e.g. the 80Hz is omnidirectional, I know)
amidr
Excellent review. These speakers have impressed me. The build quality is excellent, and I've never seen a speaker with such a good frequency response that maintains it as you travel off-axis. However, it is quite costly.
Boerd
From the review:
"The tweeter is on its own for playback around 4kHz, but distortion is still very low; at its highest point, it is still 40dB below the fundamental which is 0.5% THD"
This is incorrect: -40db is 1% http://www.sengpielaudio.com/calculator-thd.htm
Next, in the review I find a statement that is too general and probably incorrect:
"The surface area of four 7” cones have the equivalent surface area of a 14” cone, so all these bass drivers are like a 14” bass driver, except that they would have a lot more cumulative motor force than a normal 14” driver. They would also be far less susceptible to thermal compression since we have four coils to disperse heat instead of just one."
This is an oversimplification. A 14 inch driver has normally higher excursion and the coil yields a larger surface (cylindrical) for heat dissipation.
haraldo
haraldo
Would a really great musical experience impress you? Words encode and decode differently depending on who is encoding them and who is decoding them.
Maybe it would but again it's not the point of what I am looking for.... I have before heard loudspeakers that are getting rave reviews all over but to me they simply don't make it.... If they are unable to connect me to the music in a way that I am being transported into the musical event .... then it's not for me.
Perfect frequency response, extremely low distortion, impeccable engineering simply isn't enough to me.... they got to transport Tori Amos, Kate Bush or Dave Gahan into my living room right in front of me :cool:
In my humble opinion it takes a lot more, also including things we probably don't know how to measure yet!
buckchester
Is Gene still planing a shootout between these and the Revel 328? Can't wait to hear about that.
Cruise Missile
Cruise Missile
I ordered a pair of the S7t's in ebony high gloss! The weather has slowed down shipping, so here I wait *ahem* patiently.
These will be for my bedroom 2-chan. rig.
Power is from the Denon A110 integrated amp.
Sources are the Denon 110 SACD player and Mofi precision turntable Fender edition.
I am beyond excited.
haraldo
haraldo
CONGRATS, WAY COOL :cool:
The Denon is pretty powerful, isn´t it..... do you think it will drive the S7t´s well?
G
Golfx
Nice bedroom sound system. Will you ever leave? I too had the Denon AVR A110. It has excellent specs! I also have the Perlistens. You are so going to enjoy them. Congratulaions.
Cruise Missile
Cruise Missile
It should be up to the task. I've wanted to separate a 2.0 from my theater stuff for a long while. I find the damped theater spaces a bit dry for 2-chan. listening.
While I'm waiting for the S7t's I've been listening to my Aperion Versus grands on it (A110). Good budget speaker that has no business sounding this good.
I had upgraded the theater to a Denon avr110 from a 4311ci and the very real improvement with the Aperions on it was enough to kick start this new rig.
Cruise Missile
Cruise Missile
Thank you! And, not if I could manage to stay in there. Lol
G
Golfx
I meant to comment earlier regarding your choice of wattage. The original reviewer at audioholics @shadyJ recommended a more robust power amp perhaps even bi-amping especially for the bass. So if you are impressed with your current setup then fine. But if you want to push all the potential out of your s7ts you might want to consider at least 400w. I drive my LCR with hypex ncore1200 monoblocks which deliver 700w @4ohms. I have a very big room (5600 cu ft+). Yours may be ok in a bedroom.
Cruise Missile
Cruise Missile
I won't be trying to achieve THX Dominus levels in there. Lol. (Not often anyways)
The other key here is the sensitivity of the speakers, 92 db is pretty high.
I do have other amps I can try "if" the Denon can't cut the mustard with them in that space. Or if I feel there isn't enough headroom left in the amp for dynamic swings.
Gosh, I can't wait to get to play with them!
Boerd
Received my Perlisten S7T. The setup is not final - using a loaner amp from my dealer.
ryanosaur
ryanosaur
If you ever need to store them anywhere, you know, for just a week or two, I'm only about an hour away. Just holler.
G
Golfx
Congrats. I am certain they will justify your investment. I also own them. They effortlessly fill the room. Uncanny presence.
