G
Gio-G
I stated in my intro post, that I'm quite out of my depth here and don't know what a lot of the well versed, trained audio folks know. I'm not an engineer, I'm a lover of music and I feel I've been steered into making some decent decisions when it comes to equipment, although my Bryston stuff is expensive and can be done for less I have it and like it. That part is what it is. It measures well, so I'm told and I like the quality, warranty and I'm comfortable with it.
I have Perlisten S7T speakers and I'm considering two Subs.
Perlisten R12s subs (more than I want to spend) or Aredndal 1723 S1 subs. SVS is another option.
The question I have is whether most people feel an external crossover is a must or a MiniDSP?
Both Perlisten and Arendal have told me, I can hook up directly to my Bryston BP-19 via balanced XLRs and use their software and apps to tune the timing of the subs for integration and didn't seem to think running the S7Ts full range was an issue.
I am a two channel listener and really only want the bottom end of the bottom end.
I've read and reread the Audioholics S7T review and the Perlisten bass was viewed as very good. The initial review stated subs were not a must at all. I suppose that it true to a degree.
I previously used my NHT 3.3 speakers that were legendary for bass. I still have them but the Perlisten speakers are better in every area except the deepest bass.
I don't know how to take measurements or anything like that and it sounds overwhelming without help.
What do most here feel is the best route for a CD listener that wants to add some very low end?
I do boundary load (7 1/2" off the front wall) the S7Ts a little for extra bass with good results but I think a couple of subs in a diagonal layout might help out.
I probably won't do anything this year but wanted to see if anyone has tried full range and compared it to using a crossover or MiniDSP.
I'm trying to stay as basic as possible but if going beyond the company's software and apps is the best move, I will do so.
Thanks in advance for any advice, I really appreciate forums like this.
Some like the duplication of frequencies with out a proper crossover. If the speakers are capable and it doesn't sound "too much" to you, just use it and be happy with what gear you already have. If you really want multiple sub management or better bass management, then look into gear that can provide that. Personally I prefer better sub/bass management than old 2ch gear generally provides, or what a sub can provide in the way of a low pass filter (altho some subs have a limited option for implementing a crossover).
