my simple system
  • Thread starter Thread starter croseiv
Afew more shots:
Very very nice indeed....
are you able to get a seamless transition from sub's to those bookshelf speakers?
At which frequency are the ultra's crossed?
regards
-Harald
  • Like
Reactions: croseiv
regards
-Harald
Thanks Harald! Yes the crossover is pretty smooth. I am crossing over at 60 Hz (sub set at 80 Hz). Running test tones only shows a 1 dB dip at about 59 Hz. It's quite flat from 95 Hz down to 45 Hz or so. Then I have some room gain kicking in at 30- 40 Hz (PEQ helps tame that). Getting response down to about 13 Hz in 20 Hz tune.
  • Like
Reactions: haraldo
I've got to say I'm literally drooling at the moment - the dual Ultra's are something out of this world - congrats on a very clean, powerful yet elegant looking setup. :) Did you experiment with placing the Ultra's in opposing corners before stacking them to help even out the room's bass response?
  • Like
Reactions: croseiv
Thanks Halon451! :)Stacking them was the original plan, and I'll most likely stick to it. I really like the sound and imapct with this location. I don't have much additional room to experiment with. I like the tower effect.
there's probably room for two more stacked subs :D
With this positioning, are you in any way able to localize the sub's, or do they really fit in very very nicely.... You have quite low X-over, so hopefully this works beautifully :)
Which configuration are you using for the sub's looks like all ports are open?
Most definitely!
[I think I qualify as a HT addict now]
he he, nothing like a stack of large SVS sub's Think I want this toooooooo
Jokes asides, even PB13 Ultra's perform better when stacked.....
Anybody going for four of them.....
Only if one supposes they may offset the enormous energies of the Large Hadron Collider in Europe - I suppose four Ultra's might help keep the earth in balance or something... :p ;)
Yes, be sure to position them in such a way that they oppose the energy fields by the cern particle accellerators, or you may interfere with the earth rotation
I just saw where SVS has free shipping on their box Ultras.
I hope to soon see croseiv's twin towers. :)
Beware of tsunamis when he's watching James Bond movies
