Marcus Oakley's "Best Recommendation" Questions
MOSHY25
Just get a basic AVR. Or you can go with something from Extron or Crestron. They make good splitters/switchers/scalers.
WaynePflughaupt
WaynePflughaupt
It’s going to be pretty tough to find a 5-input HDMI switcher. As MOSHY25 mentioned, your best bet is a AV receiver, maybe something like the Marantz NR1403 or NR 1608.
Regards,
Wayne A. Pflughaupt
MOSHY25
If all you care about is a switcher you don't even need an AVR of that caliber. $150 Sony at Best buy but only has 4 inputs or Extron SW6 HDMI for $200 on eBay.
sholling
sholling
Find a refurbished 4K receiver. Denon makes a few with 5 HDMI ports. Or use the TV as your HDMI switch and feed audio to your existing receiver via the TV's HDMI ARC.
BMXTRIX
BMXTRIX
https://www.newegg.com/Product/Product.aspx?Item=9SIA2R66EY8402&ignorebbr=1&cm_re=5x1_hdmi_switch-_-9SIA2R66EY8402-_-Product
You are looking for a 5x1 HDMI SWITCH (not splitter). The one linked above claims HDMI 2.0 support, with HDCP 2.2 support, but some reports are that it is not 18Gb/s compliant. Not sure about that since the advertisement lists otherwise.
At $50 it is a product which gives me questionable vibes on build quality.
It's pretty much identical to the one you pulled a description from...
https://www.amazon.com/Switch-FiveHome-Switcher-Support-Wireless/dp/B076XWNQP9
So, these all come off the same assembly line in China and who knows how well they will work for you since the Amazon reviews are all over the place.
This one has over 200 Amazon reviews (which mostly suck) and a good number are 1 star reviews.
https://www.amazon.com/Awakelion-Premium-Quality-Switcher-Support/dp/B06WV5YJ6H/ref=sr_1_3?s=electronics&ie=UTF8&qid=1520789859&sr=1-3&keywords=5x1+hdmi+2.0+switch&dpID=413174W48QL&preST=_SY300_QL70_&dpSrc=srch
Some specifically talk about it not supporting UHD at 18Gb/s which is the entire point of the HDMI 2.0 specification.
I love Crestron and Extron, but they are behind the curve at the moment on HDMI 2.0 compatibility and support. The previously mentioned Extron SW6 HDMI does support HDMI 2.0 at all.
To get full HDMI 2.0 support with 18Gb/s, you need to get the SW4 HD 4K PLUS, which is only a 4 port switcher as they don't offer a 6 port version yet.
https://www.extron.com/product/product.aspx?id=swhd4kplus&subtype=233&s=8
I would get a receiver with full HDMI 2.0 support as there should be solid support for the product, and the price will be in line with a good stand alone HDMI switcher.
marcus oakley
hi
out of these 2 5in1 hdmi splitters what would be the better overall switcher to use
E-SDS UHD 4K@60Hz HDMI Switch ,5x1 HDMI Switch vs xolorspace smartooo 23051 @60hz
need it for the best audio and resolution for 65e6v oled tv
with sky q box virginmedia v6 box buzzbox xls 3000 android box
ps4 pro
xbox one x console
nvidia shield console
sony ux800 4k player
pc
wii u
which one has the best update specs thanks
marcus oakley
hi
i need a vorke hd41 pro usa to uk converter i bought it from usa to the united kingdom where i live
what can i use to use this device in the uk thanks marcus
WaynePflughaupt
WaynePflughaupt
I’m sure they have AC adapters in England? You know, these things. Judging from the picture at Amazon, you will need an 230-volt AC adapter with a 5-volt DC output.
Sounds easy, but the adapter will also need to have the correct plug end. This means both the outside diameter of the plug, as well as the diameter of the hole in the center, will have to be sized correctly in order for it to properly fit into the socket on the Vorke. In addition, the polarity must be as shown on the side of the Vorke.
Regards,
Wayne A. Pflughaupt
marcus oakley
hi
can anybody please tell me is the yamaha rx 3060 a class d amplifier
if it is not i need a top end class d amp that does dolby atmos dts x that will work with the best of its ability with the klipsh 280f speakers thanks
Verdinut
Verdinut
hi
If you're relating to the RX-A3060, that receiver has Class A/B amplifiers. AFAIK, there are no AVRs on the market at present using the Class D technology.
Why do you need Class D amps? They don't perform any better than Class AB amps. They are more efficient and heat less however.
little wing
little wing
Poineer receivers have class d amps. Don't know why he specifically wants class d amps,. Curoius post as usual from OP
Randy Hess
hi
Pioneer Elite AV receivers are listed as class D3
marcus oakley
HI
i will be buying 4 chane music 5.4 speakers as rears as fronts
a chane music 2.4 centre
using a denon 4400 amp
plus 2 other chane 2.4 as additional rears
but what about for height channels for atmos dtsx auro 3d
woud the svs prime elevation speakers be a very good match for the rest of the speakers
or would i be still better of using an additional 4 chane 2.4 speakers as atmos duties
or any other in ceiling to get maximum performance from this setup
also would the parasound a21 be a very good amp to use with the denon 4400
to enhance the audio of the 2 front speakers would it be a great match with the chane speakers
also i want to add a chane 3600 amplifier to this setup
and use 2 svs sb16 ultra subs
and 2 chane sbe 118 subs as well again will they work extremely well together with this setup thanks
marcus oakley
hi
i am after buying XMC-1, XPA-7 Gen3, pair T2, C2, 4 x E2, Airmotiv S12 Sub
is there any way of adding to this setup so i can do height atmos channels as well and dts x
normally this is 7,2
i want to do 11.2 with this setup thanks
BMXTRIX
BMXTRIX
You should contact Emotiva on this. It's listed as a 'future feature' on their website. They apparently have some idea of how this is all going to work, but I would reach out to the manufacturer first. Find out their target date and what you will need to do for wiring.
I would FULLY expect that you will need external amplification for any Atmos speakers which are in use. I expect that you may be using the other outputs for z2, etc. to accomplish this. Make sure you can do 7.2.4 with their Atmos as well.
