"Marcus" posted this on Jan 28th.
i want to add a very good monoblock to the centre speaker to enhance it greatly
i will be using my marantz as main amp
then i will use the music fidelity m3i and crown 102
for the high and low frequncies then to the marantz
to my dali speakers
will connect my blue node2 to the amplifier
my question is i have enhanced my two front speakers but i want to enhance my centre speakers as
well the dali zenor vokal centre
what do you recommend as a monoblock for the centre
same as youve got
or something else you would recommend
i am using dali instead of the kefs you use to take into consideration
also i want to enhance the audio quality of the sony ux800 4k player
by using a arcam ir dac to enhance the 2 channel music of the sony ux800
can all this all be wired up to the marantz amp
As you can see he is now talking about entirely different equipment. either he sold all of it....never had it, or just loves to make bogus posts to waste people's time.
So can you post some pics of your gear "Marcus" ? For our edification?
