Marcus Oakley's "Best Recommendation" Questions
slipperybidness
slipperybidness
hi i have bought a nakachimi 9.2.4 soundbar
my question is im after a audio specialist who can setup install and calibrate my nakachimi 9.2.4 soundbar any recommendations im situated in wellingborough northamptonshire thanks
and how much it would roghtly cost to setup
1.....MILLION.....DOLLARS o_O
slipperybidness
slipperybidness
marcus oakley
hi does the nakachimi 9.2.4 subwoofers need to be plugged in to wall sockets
do i need 3 wall sockets in total
i live in the united kingdom i bought from usa
if the subwoofer need plugs
what step down converters will i need three of them can you give me make and model
step down converters to use with the nakachimi 9.2.4 schockwave system thanks
marcus oakley
required soundbar 100-240 volt 50/60hz
Subwoofers 110-240 volts 50/60hz
Total soundbar wattage 1000 watts
what do you recommend to use with it
marcus oakley
will this do the job LVYUAN 1000W 220V - 110V Step Up & Step Down Voltage Transformer Converter UK to US & US to UK Dual 110V & 220V outlets from amazon uk
slipperybidness
slipperybidness
Depending on the cost, you may find that it's prohibitive. For the sub, the transformer needs to be able to handle the current and that's not going to be cheap. For a small appliance, it's not bad but for something that may draw more current, it's not as practical. If the sub is relatively new, it probably has a switch on the rear for voltage selection- if it does, you only need an adapter for the plug on the power cord or maybe, just a different power cord.
What's the actual model of the subwoofer?
pssstttt......you are talking to a chat bot!
Go back and check the history of this "user"
What are you talking about and where did that post from me come from? I have no idea how you did it, but I don't like my screen name used without my permission. :eek:
