M marcus oakley Audioholic Mar 26, 2016 146 0 16 55 England Dec 21, 2017 #361 hi all i have the dali ikon 6 v2 and dali zensor 7 dali vokal centre and 4 atmos dali dc1 upfiring speakers dali zensor 1 and a crown 102 amp and using a sony x800 i will be using 2 svs pc2000 subs and 2 Bic Acoustech PL-200 II Subwoofer and a miniDSP 2x4 for using 4 subs i will be using blue jeans cables i will be using dali ikon 6 v2 as fronts dali zensor 7 as rears dali vokal centre dali zensor 1s as additional rears and the 4 dali c1 atmos as atmos effects my question is what would be the better partner the marantz 7010 or the denon 4400 what would be the better for all out action blockbuster movies overall with this setup Reactions: its phillip
lovinthehd Audioholic Jedi Sep 11, 2012 44,872 0 113 Oakridge, OR Dec 21, 2017 #362 Good grief here we go again. Reactions: pewternhrata
William Lemmerhirt Audioholic Overlord Jan 8, 2017 12,005 0 113 52 Dec 21, 2017 #363 Pretty sure you wouldn’t be able to tell the difference. I would buy the denon and save some money, then use that for two more pc2000. I wouldn’t mix the bic and SVS subs. Unless the bics are right behind the couch. Even then, I probably wouldn’t.
A aschamne Audioholic Intern May 20, 2012 29 0 3 Dec 24, 2017 #364 Instead of spending 850 on 4 crap subs, why not spend 1000 on 2 good subs and call it a day? https://www.amazon.com/SVS-PB12-NSD...ywords=svs+pb12-nsd&psc=1&smid=A21759W3TJTNCB
M marcus oakley Audioholic Mar 26, 2016 146 0 16 55 England Dec 31, 2017 #365 hi can anybody tell me if there are Important any search tools or websites that allow you to search for the perfect sub or amp to use with your speakers or speaker packages thanks Reactions: its phillip
P pewternhrata Audioholic Chief Jul 25, 2006 921 0 43 Dec 31, 2017 #366 Too many variables come into play for such a thing. Start with room size and the results you are looking to achieve. This site is great for info as long as you engage in conversation.
H highfigh Seriously, I have no life. Sep 14, 2008 24,219 0 113 Dec 31, 2017 #367 marcus oakley said: hi can anybody tell me if there are Important any search tools or websites that allow you to search for the perfect sub or amp to use with your speakers or speaker packages thanks Click to expand... Room EQ Wizard has a tool that models for main speakers and sub placement, in three dimensions. If you're asking if someone has a way to tell you quickly, then I would say no- it's not so simple.
M marcus oakley Audioholic Mar 26, 2016 146 0 16 55 England Jan 9, 2018 #368 hi hi can anybody tell me if anyone has tested both the marantz 7010 and denon 4300 using the dali zensor speaker package and can tell me what is the better amp for sound quality which is the better performer overall i have been told that dali speakers suit warmer amps overall so maybe more suited to the marantz partnering i was told the denons are more neutral sounding i no i have asked many questions on this topic but i defenitly want more opions before on which amp to purchase or maybe even the denon 4400 or marantz 7011 thanks Reactions: little wing, its phillip and lovinthehd
M marcus oakley Audioholic Mar 26, 2016 146 0 16 55 England Jan 10, 2018 #369 forgot to add i will be using a 11.4 system using 4 pb 13 ultra subs i have changed my subs and a crown 102 amp Reactions: little wing, its phillip and lovinthehd
P PENG Audioholic Slumlord Oct 23, 2004 19,797 0 113 Ontario Jan 10, 2018 #370 They have almost the same amp specs and based on bench test results of a similar Denon AVR-X4200W https://www.soundandvision.com/content/marantz-sr7010-av-receiver-review-test-bench https://www.soundandvision.com/content/denon-avr-x4200w-av-receiver-review-test-bench they should sound the same in pure direct mode. Marantz SR7010: 2 channel driven at 0.1% THD - 128.7/201.7 watts, 8/4-ohm 5 channel driven at 0.1% THD - 84.3 watts 7 channel driven at 0.1% THD - 83.2 watts. Denon SRX4200W: 2 channel driven at 0.1% THD - 124.3/215.9 watts, 8/4-ohm 5 channel driven at 0.1% THD - 94.6 watts 7 channel driven at 0.1% THD - 76.8 watts. The Marantz "warm" sound thing is just forum talk/hearsay, not facts.
little wing Audioholic General Sep 4, 2005 1,174 0 63 Jan 10, 2018 #371 marcus oakley said: forgot to add i will be using a 11.4 system using 4 pb 13 ultra subs i have changed my subs and a crown 102 amp Click to expand... Just a bit of advice - You may want to address your grammar and sentence structure issues. 4 1000 watt subs with 13' drivers?? My what a large room you must have.......Anyways, PENG set you straight..you should be good...
lovinthehd Audioholic Jedi Sep 11, 2012 44,872 0 113 Oakridge, OR Jan 10, 2018 #372 Don't feed the troll.... Reactions: Montucky and little wing
M marcus oakley Audioholic Mar 26, 2016 146 0 16 55 England Jan 11, 2018 #373 at the moment i have 2 dali ikon 6v2 fronts dali vokal centre 2 dali zensor 7 as rears 2 dali zensor 1 as additional rears 4 dali c1 atmos modules i also have the crown 1002 amp as well sony x800 4k player blue jeans speaker cables 4 svs pb13 ultra subs a playstation 4 pro a wii u xbox one x scorpio edition i am after buying a marantz 7010 if i was to buy the marantz 7010 would i be better off buying the marantz pm6006 or still using the crown 1002 amp that ive got overall thanks if i was to wire the 2 front dali ikon 6v2 to either of the crown 1002 amp or the marantz pm6006 using the marantz 7010 which would produce the better sound quality and performance thanks Reactions: its phillip, little wing and lovinthehd
M marcus oakley Audioholic Mar 26, 2016 146 0 16 55 England Jan 11, 2018 #374 hi i have 3 rbh mc-815 in ceiking speakers to sell brand new boxed asking £250 bank transfer or cash on collection collection on items only
M marcus oakley Audioholic Mar 26, 2016 146 0 16 55 England Jan 11, 2018 #375 hi i have a samsung galaxy s6 edge plus mobile phone used has some wear and tear 2 slight chips on front of phone but once lit up in use can barely notice has power adaptor as well asking £180 bank transfer or cash on collection or i can post for additional fee
M marcus oakley Audioholic Mar 26, 2016 146 0 16 55 England Jan 14, 2018 #376 hi i will be using dali ikon 6v2 fronts and the rest are dali zensor speakers my question is i want very good performane speaker cable that will enhance the characteristics of what the speakers are capable of doing they will be connected to a marantz 7010 amp at the moment i have blue jeans Belden 5000UE speaker cable would this still work very well with the dalis or is it worth changing the cable thanks Reactions: little wing and its phillip
M marcus oakley Audioholic Mar 26, 2016 146 0 16 55 England Jan 14, 2018 #377 hi i need a wall mount for my dali zensor vokal centre what can anybody recommend using thanks
BMXTRIX Audioholic Warlord Sep 16, 2004 8,803 0 113 Jan 15, 2018 #378 If your length of cable is under about 60 feet, then there is not a better cable to use. http://www.audioholics.com/audio-video-cables/speaker-cable-gauge Last edited: Jan 15, 2018 Reactions: j_garcia
Montucky Full Audioholic Mar 18, 2015 463 0 43 45 Jan 15, 2018 #379 Agreed. I love pretty cables (about the biggest reason to "upgrade"), but if you already have a decent gauge wire and not pushing crazy distances, you're not too likely to notice any differences. The only time I've witnessed a difference was when a builder ran like 22 gauge (shameful) in-wall about a 100'+ distance. That got swapped out with 12 gauge. THAT was better. 22 was the worst I've ever come across. That Belden 5000UE's great stuff. 12 gauge, right? It's going to be tough to get any better than that unless you just want to go for different aesthetics.
H highfigh Seriously, I have no life. Sep 14, 2008 24,219 0 113 Jan 15, 2018 #380 marcus oakley said: hi i will be using dali ikon 6v2 fronts and the rest are dali zensor speakers my question is i want very good performane speaker cable that will enhance the characteristics of what the speakers are capable of doing they will be connected to a marantz 7010 amp at the moment i have blue jeans Belden 5000UE speaker cable would this still work very well with the dalis or is it worth changing the cable thanks Click to expand... Wire has very little to do with sound quality- it's the speakers and room that matter most.
