Marcus Oakley's "Best Recommendation" Questions
speakerman39
speakerman39
Hello Marcus many here will be more than happy to help you. However, we need a bit more info first. Like how big is your room? Is the room open to other areas? What is the budget? More importantly, how far is your MLP from your front-stage? Lastly, are you primarily a HT guy? Or, perhaps you listen to a lot of music as well? A lot of people are 50/50 whereas others like me are merely mostly music. Once you give us a bit more info, then we can help you. Are you in the US? Thanks!
Cheers,
Phil
shadyJ
Speaker of the House
Staff member
I would be looking at the VTF-3 mk5 or VTF15h mk2 if it can be afforded. The others are good too, but those are the top dogs.
marcus oakley
hi
i have got the dali ikon 6 mk2 speakers for fronts
dali vokal centre
dali zensor 7 as rears
dali zensor 1 as additional rears
and 4 dali alteco c1 atmos modules
a denon 4300 amp
a crown xls 1002 power amp
blue jeans speaker cable
can any body tell me if the BIC Formula F-12 if i was to use 4 of them
would they work great with the zensor and would they sound fantastic with blockbusters action movies with it give me very deep bass would it shake the walls would it be good with music i will be using mini dsp 2x4
everettT
everettT
My suggestion is to start multiple threads dealing with the same topic so that answers are spewed all over the place. If you spend $1600 on your mains, why buy budget subs?
hi
dali vokal centre
a denon 4300 amp
I think ol' Marcus has a posting problem and a credibility problem. Seems he posts about fantasy systems. Pics of current in-room setup or it isn't happening.
Bucknekked
Bucknekked
Has the OP gone AWOL? ;););)
Cheers,
Phil
Phil
No the OP has not gone AWOL. The OP is Marcus Oakley. The only thing Marcus does is post questions about which of two options is best. He does not follow up on the post. He never comes back to the post. He doesn't get involved in conversations on posts. Marcus does just one thing. He asks, which of these two things (sometimes its 3 things) is best. That's it. I have no idea if he knows anything about the questions he is asking. He just asks. Its surprising at this point in the movie that people still respond and some of them respond with lots of info.
speakerman39
speakerman39
Phil
Thanks for the info. Will keep this in mind. I just thought that he went AWOL. Just trying to be helpful. :):):)
Cheers,
Phil
marcus oakley
hi
my room is 15 x10x14
the room is open to all areas
the budget is £400 each sub
my mlpp is 6 feet
it is primarily for home theatre
80/film 20/music
im in the uk
marcus oakley
can anybody tell me if you compare the hsu vff3 mk2 vs the hsu vtf 15h mk2
is there much difference in performance terms and in bass quality and how deep they can go in bass terms for action movies
shadyJ
Staff member
The VTF-3 mk2 is a much older sub, and far weaker than the VTF15-h mk2. Do you mean the VTF-3 mk5? The VTF-3 mk5 is a lot like the VTF15h mk2. The chief difference will be low end performance. The VTF15h mk2 will be able to stay cleaner at louder levels in deep frequencies than the VTF-3 mk5 due to the larger ports and enclosure size. This won't affect performance above 35 Hz or so, so it is only applicable to deep bass.
KenM10759
KenM10759
In the UK you also have easy access to BK Electronics and M&K subwoofers. SVS also has a lot of distribution there. I'm just suggesting Hsu Research isn't your only option. I think the BK subs are pretty good and the company being based there you might escape a larger VAT fee. According to their website, they started by making subs there for REL, a Canadian company.
Auditor55
Auditor55
For clean bass you should get SVS subs.
Auditor55
Auditor55
If I said "musical bass" instead of "clean bass" would you still give me a Dumb x2;)
Bucknekked
Bucknekked
remember, this is Marcus Oakley as the OP. One line responses are overkill. A paragraph, well, its bigger.
He won't see your response. He won't ever check back. He is Marcus Oakley. I love the guy's endless search for knowledge at someone elses expense.
marcus oakley
hi im after buying a 4k tv 65 inch with hdr for $1000
im after the closest to oled tv picture quality terms for hdr and films sports possible
shadyJ
Staff member
I am told that Ford motorcars make the best 4k TVs nowadays, but I don't have any verification of that.
