Or maybe even factory reset? Sent from my iPad using Tapatalk
G Golfx Senior Audioholic Nov 20, 2021 #21 Or maybe even factory reset? Sent from my iPad using Tapatalk
C comunicator2009 Junior Audioholic Nov 20, 2021 #22 There is no problem. This is the reason I am asking here, maybe there is something that I didn't do. No, I didn't do that. Can you be more specific please? Thank you so much. Sent from my EML-L29 using Tapatalk
C comunicator2009 Junior Audioholic Nov 20, 2021 #23 I did the factory reset. Sent from my EML-L29 using Tapatalk
E enrique Full Audioholic Nov 20, 2021 #24 well i would plug into sub1 and go thru test tones.. no tones on sub no sub Sent from my iPhone using Tapatalk
G Golfx Senior Audioholic Nov 20, 2021 #25 All denon and marantz AVRs have a new first time setup procedure that will walk you through “amp assign” and speaker choices procedure. Usually at the bottom of choices from the “gear” button on the remote. Sent from my iPad using Tapatalk
E enrique Full Audioholic Nov 20, 2021 #26 was actually going to mention the amp assign Sent from my iPhone using Tapatalk
C comunicator2009 Junior Audioholic Nov 20, 2021 #27 I will go in a few hours and I will make some photos. Sent from my EML-L29 using Tapatalk
C comunicator2009 Junior Audioholic Nov 20, 2021 #28 Since this is a 11.9 channel receiver and I don't have yet the Atmos speakers, the setup speakers are 5.1 Sent from my EML-L29 using Tapatalk
G Golfx Senior Audioholic Nov 20, 2021 #29 Sorry for the disconnect I am suggesting you run the setup procedure. If its hooked into a tv via hdmi you can see the options better. If not you can read them off the front of the marantz’s front screen itself. There should be a “setup” or “gear” button on the remote. There are also some YouTube videos of setups that can help if you are unfamiliar with the procedures. Good luck. Sent from my iPad using Tapatalk
lovinthehd Audioholic Jedi Nov 20, 2021 #30 That the issue persisted after a factory reset isn't a good sign. Going carefully thru setup is needed it sounds like, tho....it's not particularly a plug'n'play kind of thing. Good luck in figuring it out.
C comunicator2009 Junior Audioholic Nov 20, 2021 #31 I will go again with the settings. I will keep you posted. Thanks a lot Sent from my EML-L29 using Tapatalk
lovinthehd Audioholic Jedi Nov 20, 2021 #32 comunicator2009 said: I will go again with the settings. I will keep you posted. Thanks a lot Sent from my EML-L29 using Tapatalk Click to expand... Are you familiar with running Audyssey setup? You have the mic?
C comunicator2009 Junior Audioholic Nov 20, 2021 #33 Yes, I have the mic and I have done the settings....and no sw1 Sent from my EML-L29 using Tapatalk
lovinthehd Audioholic Jedi Nov 20, 2021 #34 comunicator2009 said: Yes, I have the mic and I have done the settings....and no sw1 Sent from my EML-L29 using Tapatalk Click to expand... Done the settings?
C comunicator2009 Junior Audioholic Nov 20, 2021 #35 Audyssey setup I mean Sent from my EML-L29 using Tapatalk
lovinthehd Audioholic Jedi Nov 20, 2021 #36 Then again since subwoofer 2 works and you've already figured out a workaround it sounds like it would still be functional.
C comunicator2009 Junior Audioholic Nov 20, 2021 #37 The SW2 is working, the SW1 is not working with Audyssey setup. Sent from my EML-L29 using Tapatalk
lovinthehd Audioholic Jedi Nov 20, 2021 #38 Does negate the potential of XT32/SubEQ for two separate sub adjustments, then.....you might try a few factory resets in a row....can sometimes fix things but yours could be a physical connection issue as well perhaps.
C comunicator2009 Junior Audioholic Nov 20, 2021 #39 I really don't know what is the problem there. I will try again. I have tried also with another SW and the results are the same. 1 not working....2 working Sent from my EML-L29 using Tapatalk
lovinthehd Audioholic Jedi Nov 20, 2021 #40 comunicator2009 said: I really don't know what is the problem there. I will try again. I have tried also with another SW and the results are the same. 1 not working....2 working Sent from my EML-L29 using Tapatalk Click to expand... Starting to sound more physical than software/firmware related. Could be a poor solder joint or perhaps someone yanked on the jack by tripping over a sub cable or something....hard to know with used gear. Any chance the previous owner will help out?
