Logitech Harmony 520 $29.99
  • Thread starter Thread starter Nomo
Don't get the Harmony 520 if you want to control the PS3. I beleive teh pS3 uses r/f which that Harmony remote does not do.
You wish the PS3 used RF. There are plenty of universal RF remotes (thought pricier than their IR only counterparts.) The PS3 uses Bluetooth which is something no universal remote does at this time. There are several IR to Bluetooth adapters for the PS3. It's really a non-issue nowadays.
Bluetooth isn't a frequency band like IR or RF. I suspect Bluetooth uses an RF that falls outside the normal RF bands for remote controls. This converter that you mention is very interesting. Do you have any brnad names, names of retailers that sell that? :)
Yep. There's a big thread on AVS.
http://www.avsforum.com/avs-vb/showthread.php?t=1016741
To save time, the most popular remote is the $50 IR2BT. However, it's discontinued.
Now, we're looking at the IR2BTci for $150 -- http://www.ir2bt.com/info.htm
There's the PS3IRPRO for $100 -- http://www.schmartstuff.com/ps3irpr3.html
Moreover, there's the PS3 Tooth Fairy -- http://www.ps3toothfairy.com/
There's also one more product (the original IR to BR converter) that's small and cheap, but doesn't allow you to turn the PS3 on/off remotely except with one of the PS3's controller. It's $15 -- http://www.amazon.com/PlayStation-3-Blu-Wave-Remote/dp/B000R5H7KE/ (Referrer tags removed!)
  • Like
Reactions: 3db
