I just did the subwoofer crawl and the bass was louder in the foyer by the front door (no-go) and loudest up on the balcony on the right side. I put the sub up there on a table and ran Audyssey. It's crazy how I am able to hear it like it's right in front of me in the living room
![Big Grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
. So two 15's is looking like it will work. I can put one in the living room to the left of the mains (where I originally had the SB-1000) and another up on the balcony. Does this sound like a good plan?
The sub on the balcony will be in a corner, which I read is not ideal, but I should be able to correct any cancellation with the miniDSP correct? Furthermore, will connecting the upstairs sub with a wireless module and the downstairs one via hardwired RCA cause issues?
Only downside is my daughter's room is on the other side of the wall, so no subs when she's asleep. I suppose the bass was loud up there before though.
Anyways, pretty excited about getting dual subs. Just need to decide between the HSU ULS-15 MK2, PSA S1512, or Rythmik E15HP. If there won't be much difference between these three, I suppose I'll go with the most economical option, which is the ULS-15 MK2. The guy at PSA said HSU subs are made in China, but the website says Designed and Engineered in the USA. Guess maybe they are assembled in China?
