moves
moves
These are the speakon terminals I use on the cabinets https://www.parts-express.com/neutrik-nl4mpr-speakon-connector-4-pole-round-chassis-mount--092-054, use these for terminating the speaker cables https://www.parts-express.com/neutrik-nl4fx-speakon-spx-series-4-pole-cable-connector--092-190 (plus some right hand angle ones lately).
What types of cables should I be considering to connect the amp to the back of the speaker cable connectors on the back of the cabinet? Or do cables come with the driver?
I attach the Speakon connectors to 12g speaker wire. Drivers won't come with any wire/cables. Altho not sure that's what you're asking...
moves
moves
Not quite clear on how to make the connections..... The speakon cable plugs into the crown and the crown plugs into my Pioneer SC27 AVR...
How is this used? https://www.parts-express.com/neutrik-nl4mpr-speakon-connector-4-pole-round-chassis-mount--092-054 does the speakon plug into the centre of this plate?
Do I need to get a 4 conductor cable or a 2 to wire the driver to the amp?
My Pioneer does not have XLR.... so does that mean that I would have 2 XLR cables coming from the 2 crown amps and then those will be split with some kind of adapter to it converts to RCA that can plug into the subwoofer input on the back of the Pioneer?
everettT
everettT
Speakon is from crown to the speaker. From the AVR its rca to xlr. If it's the newer crown, set the input to .775 and you can run rca to rca.
moves
moves
I didn't buy the crowns yet but I will be getting 2 XLS 1502s.... they accept the speakon connection?
How do you connect the cable from the driver to the speakon cable going into this? https://www.parts-express.com/neutrik-nl4mpr-speakon-connector-4-pole-round-chassis-mount--092-054
Before I buy all this, is it safe to say that the Pioneer SC27 can handle the 2 additional amps for sub use? Do the amps plug into the subwoofer input (RCA)? The AVR only has one subwoofer input.
everettT
everettT
The avr will have no issues. The speakon connection is a speaker level connection, so if the sub amp and the sub have them it's just that simple. 4 pole connectors aren't used unless your bridging or biamping, yours will just use 2 unless your doing the aforementioned. From the avr just use rca to rca in on the crown
moves
moves
I will be bridging the crown's 2 channels into 1 for the 18-22 ultimax. I will be making another cabinet with another 18-22.... 1 crown for each sub.
What type of adapter do I need to connect the 2 amps into the 1 RCA subwoofer input? Or is this where it should even be plugged into the AVR? Also, I thought the XLR is a preferred connection over RCA... however, maybe there isn't any benefit it is RCA on the other end?
everettT
everettT
The sub in to the Amps is RCA to RCA. If your bridging this video discusses the pinouts from the amp to the sub. It's very easy just take your time and double check as you dont want to fry either
EverettT has pointed you in the right direction, altho I use rca to rca for the 1.4V input on my Crown XLS 1500s without issue, you may not need the .775V setting.
Keep in mind the direction of the signal. Your avr has no subwoofer inputs (unless it has a multich input for use with analog outputs from a dvd/bluray player or similar). The relevant connection in your case would be the subwoofer pre-outs (outputs) on the avr to the inputs on the amp (Crown XLS has a choice of rca, xlr or 1/4" inputs).
As far as connecting the driver to the terminal in the sub cabinet, you can use pretty much any handy speaker cable as the length is short, I use whatever's handy, 14g, 12g, etc. That is what I was wondering if you were asking earlier.
Summarizing for your avr to Crown amp rca to rca coax cable.
From Crown amp to sub if using speakon connectors at both ends, just use appropriate gauge speaker cable/wire with the speakon connectors.
From driver to the speakon terminal on the sub cabinet...pretty much any handy speaker cable (if you're getting 12g for the longer length, a bit of this will do just fine).
moves
moves
Just wondering HOW to connect the driver to the back of the chassis that is mounted on the back of the sub.... is it just a simple screw that holds the wire down or do I need to purchase another connector?
Thanks guys!
moves
moves
Sorry I thought amp to sub is speakon to speakon.... do you mean AVR to amp?
everettT
everettT
The sub out on the AVR or PrePro is rca out to rca in on the crown, then speakon from the crown to speakon in on the sub
WOuld I need a 2 or 4 conductor wire? I am guessing a 2?
Speaker wire is a 2 conductor unless you want to increase the effective gauge by using 4 conductor and twisting a pair of ends together. RCAs are coaxial.
Thanks guys!
Some drivers use a simple spring clip, others may use another type, some would just accept bare wire ends, or another type of connector (I want to say spade, but that's not the right name) (some prefer to solder them in place, too). The speakon terminal on the sub cabinet you'd also use bare wire ends and secure them with a screwdriver (or again, you can solder them in place).
ps Here's what I was thinking of as "spades" https://www.parts-express.com/1-4-(16-14)-female-disconnect-crimp-terminal-blue-50-pcs--095-280
moves
moves
I asked about the 4 or 2 conductor wire and this is what Solen said:
Well since it is a dual voice coil subwoofer, it has 2x + and 2x - terminals.
You can either run a 4 conductor or a 2 conductor speaker wire. If you choose to go with the 2 conductor, you will need a 2nd 2 conductor wire between the two voice coil connectors.
This just means connect +1 and -1 on the speakon and then connect +2 on one voice coil and -2 on the 2nd voice coil?
everettT
everettT
Just wire the sub driver separately, so you only have 2 wires between the speakon. So jumper wire between each coil .
moves
moves
Sorry another question.... Just wondering why you recommended the 4 pole speakon connector when using a 2 pole wire? Wouldn't the https://www.neutrik.com/en/product/nl2mp and the https://www.neutrik.com/en/product/nl2fx be more appropriate?
I just need it to fit a 12 AWG speaker cable.
