That Crown model does not come with the dsp he needs, though, need to step up the Crown ladder to get that. The dsp in the XLS Drive Core series is more about a crossover for pro use of different monitor/bass bin, particularly no eq and no high pass filter low enough for his needs. The dsp in the Behringer is quite good, though fwiw. The Crown XLS amps are what I use, I have several 1500s (mine are first generation, second gen, i.e. xx02, has different appearance, adjustable sensitivity, adjustable panel light, and a trigger of sorts but same amp section and dsp).
