The flatpack will come with the baffle cut for the driver (if you order from diysoundgroup.com check for the diameter for the particular driver), but not for whatever you use for wire terminal (I recommend Speakons). As long as you have the tools, don't mind the mdf dust, build your own box, much cheaper; I used baltic birch plywood myself. A router is nice for cutting the hole for the driver, but you could get away with a jig saw.
