What's
so horrible about a room correction system making some frequency corrections to your speakers as well? That used to be a marketing thing back in the 90s when DSP speaker correction was looking to be a thing. I mean I might as well not bother with DIRAC with my Carver speakers as they are dipolar (loads of room reflections I don't really want to correct as they are what gives the speakers their imaging. If anything, I'd rather correct the speakers themselves (near mic) than the room.
So what is it, then? You correct both, you end up moving to the left or right, but neither is correct? Can your brain tell the first arrival from the reflections so well you'd even actually notice? Is it known/tested to sound worse? How could you ever REALLY correct the room when reflections are always going to be at the mic location? Wouldn't you need to measure something like the close mic (pseudo anechoic) and compare and then subtract the difference and then alter the difference alone?
I played with Audyssey full range on my home theater system and I went one cardinal sin even further. I left my matrixed speakers ON when I corrected the room (seeing as it's not really practical to correct them separately and they will mix with the other speakers as well to create the overall arrayed phantom image, so isn't it the arrayed sound I'd want to be "even" rather the individuals since they are not discrete with a matrixed array?).
Thus, I was going for an averaged room response rather than a corrected room response. I suppose you can talk about timing and how the brain differentiates such things, but what I hear with my ears and measure with a meter with sin wave tones and pink noise is uneven response at the listening position. Why do I care if it's a direct wave, reflected wave or rather the combination of the two so long as my 150Hz bass tone is no longer 10dB lower than my 80Hz tone? Because I can HEAR the difference between the tones and my brain doesn't know why it's uneven, it just doesn't like hearing the bass on George Michael's "Cowboys and Angels" drastically changing volume between notes as it's quite noticeable when it does.
After correction? EVEN STEVEN.
But that's within the whatever the guy's name I can never remember (Heinz, Oscar Meyer, Chef-Boy-R-Dee...darn I'm getting hungry) so maybe it then sounds like crap at higher ranges? Well, that's where it gets a bit more interesting. I tamed the room with a combination of absorptive things and diffractive things and odd shaped things so it doesn't sound terrible to begin with, but I did notice sibilance got noticeably louder with some songs the first attempt. I tried again after changing the toe-in a bit on the mains and it was MUCH better sounding. But in "Flat" it''s a bit harsher, if not more sibilant again.
So then is it bad sounding "flat" or am I used to hearing ribbon speakers that naturally roll off above 15kHz (oddly emulating a record player in some respects) and that colors my view, at least for a preference for "reference" over "flat"? Sibilance is more in the 5kHz-8kHz range, though so maybe not. I do know that it sounds better as long as the songs don't have sibilance issues, but if they do, it does make them slightly more noticeable. It's probably something I could tame with the editor, but it was much better the second time so I haven't bothered (very slight).
But then am I even hearing a difference between the two at all? I've flipped Audyssey on/off and reference/flat to compare (it'd be nice if they had a slightly easier method to do so without having to bring the menu up like a direct rotate button or something, preferably that could switch faster as your short term frequency type memory is pretty short indeed in small increments). Sometimes, I'm at a loss period between on/off. Clearly, it's only affecting certain ranges in a noticeable manner. Bass wasn't even "that" uneven to begin with. It's when it's off by 6+ dB that it starts to really stick out.
Then there's the question of if I'm not "really" hearing much of a difference, did I even need a room correction system to begin with? I mean people choose their AVR on room correction systems (given the lack of DIRAC when it's considered to be on the of, if not the best system), but is it a REAL palatable difference or one that exists primarily in one's sense of "I know it's more accurate now" ? I can't answer that question because I'm still wondering it myself. I tried limiting the correction to 200Hz. I could barely hear any difference at all. The predicted graphs looked good, and now that I have my UMIK-1, I can go measure it with REW to see how close it came, but did I buy the system to look at graphs or should I expect to actually notice a big improvement? So many state it's worse sounding with full bandwidth, I have to wonder if the entire system should be questioned to a certain extent.
Why even bother when a parametric EQ (Mini-DSP) can correct your sub bass (there's even a DIRAC option there as well) and say screw the rest? Yeah, that's only to 80Hz-100Hz (it's a pain to do 11-17 more channels individually with external equipment), but it's typically where the room has the most issues. But even then, it can't work miracles. Nothing replaces a bass trap and nothing tames high frequency reflections quite like absorptive/diffractive offsets (I had god-awful slap echo not so long ago 1/3 into the room (was it audible with sound? NO IDEA, but it sure was if you clapped or yelled in that space) and two tapestries wiped it out like it never existed).
I dunno. I guess I really haven't looked into the acoustical theory and math behind all these corrective issues, but somehow I thought I'd actually "hear" more of a difference overall than I did. I'm pretty certain if someone had put in a dummy switch and told me it was on/off and it wasn't changing at all, but just blanking out for a second or two, I'd probably have believed them based on sheer suggestion alone (or maybe it's just more noticeable in a bad room than one with decent acoustics? Or even with bad speakers (if it's trying to correct them)? Hmmmm.
Me: Oh yeah, it sounds "smoother" now!
Dude with switch: (It was off)
Yup. It must be that high frequency correction that sucks.
(but it's bandwidth limited)
Um. Well, I like it better off.
(It's been off the whole time! Foooooollled You! [in Dark Helmet's voice]).
Damn you Gustafson! (in my best impression of Walter Matthau)
Think I'll go watch Grumpy Old Men now....
