Help with cables
  • Thread starter Thread starter alm958
Yeah, well, some speaker cable IS shielded and it's usually for fixed voltage ysstems- I have seen and installed it when I worked for an audio contractor in the late-'90s. It's used for installations where the areas where the runs are crowded with many types of cables and with different signals- some buildings need cabling but access by human installers is difficult, if not impossible, so it's a matter of "get it in and we'll let shielding be our friend. If a problem occurs, we'll deal with at one end or the other, or both".
Belden makes 12/2 shielded cable that's made for this- I'm going to contact them to get more info.
My 16ga, twisted pair, shielded communications cable has a run of 30 feet and do not use the ground wire. Speaker/AVR application is only a few ohms. It is not around any high electrical cable installations, that requires grounding. lol Nothing to worry about folks. @highfigh, your comment is dead on. Fortunately my application is not of concern. My wire was free, from an electrical contractor, where my son works. I think I have 300 ft left over from a partial box roll. lol
I don't think I have any interference[EMI] conditions, where shielded cable is reqjuired
I'm happy with my 12-gauge copper speaker and canare interconnects from World's Best Cable on Amazon. Pretty inexpensive for what they are. For me no need to spend more.
  • Like
Reactions: Mark E. Long
I like Worlds Best cables rca’s and I do use canare 4s11 speaker cable although I made mine own speaker cables useing mono price Affinity banana’s made a nice cable .
It's still an example of a cable that caused amplifiers to puke.
Way back then, there were speaker cables with a lot more capacitance than Kimber.
And now with better high speed power transistors and better amplifier designs, Kimber shouldn't be a worry.
(other than its way too high price)
Still, back in my Logan days driving electrostatics, I did my best to keep cable capacitance to a minimum.
How much higher is the speed of output transistors now? I have had amplifiers that were spec'd at 100KHz and 200KHz on the high end and 0Hz or .1Hz on the low end- they were made in the mid-1970s.
Kimber is the only brand that I knew of which killed amplifiers- others may have, but I didn't hear about them. I do know that there was far less BS in the audio business WRT cables and accessories, though.
Also, I have never used banana plugs on speaker wire.
I started adding banana plugs to the cables I made and now use on all my speakers. It’s easier if I need to unplug.
  • Agree
Reactions: MrBoat
Yep, these days I always use cables terminated with banana plugs with my speakers.
  • Like
Reactions: Bobby Bass
200 kHz is more than enough for an amplifier. It's the output transistors in the feedback loop that need the speed.
Remember what was called the TIM problem?
Those frequencies were shown in an integrated amp I bought in about 1980. It could be done then, it should be possible now but I don't see it in most models.
Very well but just as the FTC stopped requiring that THD and power output be tested in the same way as it was in the past, I think TIM went away as well. I just checked the specs for the Parasound A23 (the model I have) ad it shows IM at .004%, but it's not called TIM.
Do you have test results for AVRs that include that spec?
