<font color='#000000'>no my mains are simple tower speakers with 12" for lows. In my other set-ups (family room and bed room both 20x20) they eliminate the need for an stand alone sub. They boom pretty darn well, crisp and clean. for some reason I am not getting that from the denon.
The Hz setting i mentioned refers to the "cross-over frequency" (looked at it again last night) It is a setting for the entire sys it is not specific to one speaker. so I am sorta confused. It sounds best (I think) when set at 40 hz. Any suggestions or insight on what exactly this does?
The auto set-up needs the mic. I refuse to pay for the mic and Tweeter said the manual set-up is better. I may just go by there this week-end for some help. I just hate asking those guys for help. Sound so much like a newbie. I do have an ego u know.
thanks for the advice on using another mic. I missed that in the manual.
As for those thinking about buying the Denon, I played with it again last night and made more progress that b4. I set the highs, mids and lows a little higher and the sound got much better. I had the mids too low and that is why I was getting the muddied voices.
The sound is much better than with my yami. I love my yami but it can be a bit bright with my speakers.
JBL S312 II (fronts), JBL S-Center II or Infinity Alpha 37C (center) not sure which I like best yet, JBL S26II (rear and rear back). The Jbl studio series speakers are great for movies. absolutely wonderful!
The remote on the Denon is great. the switching from tv to dvd just by clicking one remote is awesome. I have a Mitsubishi XD300 projector to this a great set-up. I only have to have one line going to the projector. wonderful!
I think I like the yami set-up better (may be biased b/c I have had the yami for 2yrs). I may also like the auto mode better. just not sure yet. I have only had the Denon for about 10 days.
The Denon is also much warmer than the yami. great since both of my center channels are bright and need to be lowered for the best sound.
For music, the 7 channel stereo mode is nice. fills the room with clean sound. the tuner seems a bit weak. most of my channels are static. not that bad with the yami. I may need to hook it up to my house antenna.
Overall so far, I love the Denon. I am not sure if I would have had the set-up issues with the yami vr 2400 (was about to buy this) but that just may be my learning curve.
but if anyone can enlighten me on the questions I posed in my first post I would be grateful.
Thanks</font>
