Enter to Win: Rives Audio Test CD 2
Status
Not open for further replies.
Joel47
Onix Ref 0.5 x2 for mains, Rocket RSC200 center (all "Monitor" type, I guess). I think $700/pair would be sufficient for good quality mains.
8
808htfan
Contest Question: What type of speakers are your mains (left and right channel)? Monitor, Planar, Horn, In/on wall, etc.? If you were to shop for new main speakers (for either a two channel or home theater setup) what would you think you'd have to spend to get an acceptable quality of speaker?[/I
My mains are Monitors. I think for just under $1K there are HT setups many would be happy with.
DMD123
I have JBL Studio Monitors.
I am looking for new speakers right now and seem to be looking in the $2000 price area for just the fronts.
W
WeAreSurrounded
My mains are floor standing monitors: Paradigm Monitor 9s v.2
Would like to upgrade to Paradigm Reference Studio 100s (probably under $3K), but really dreaming about Paradigm Signature series.
speakerman39
speakerman39
Currently, I am using floor-standers as my front left and right speakers. More specifically, I am using the Infinity Primus 360's which offer great bang for the buck. However, if I were to upgrade my current speakers I would exspect to spend at least $400-$600 for the front left and right speakers alone. Furthermore, a center-channel speaker and a set of rear surrounds would also add additional costs. In other words, for a complete 5.1 set-up I would expect to spend at least $1000 to have better than what I do now. Keep in mind that this price does not include the cost of a powered subwoofer.:) :)
V
Vanhoecke
Contest Entry
Current 5.1 in my family room uses Bose cubes on wall. High SAF, not real HT quality.:cool:
The HT I'm currently building in the basement is spec'd out for a 7.1 Axiom 80-600 system so I guess the answer is about $4800.:p
F
Fierce Mice
My mains are monitors. I'd love to try planar speakers, but WAF would be low, so I think horns are a reasonable possibility that I've been curious to experiment with.
I haven't priced horn speakers, but I would expect ~$2k should get me an acceptable quality of speaker.
Parrothead
DCM time frames
Floor standing
500 each
U
upyourkilt
contest
My fronts are polk rt800 floor standing. I think $1200.00 is a good price .
W
wingzz
My mains are AR970 Boston monitors
When I do up grade speakers my budjet will be around $2000
slearn
I have Jamo 707i's for my left and right. I've already decided to replace these with Axiom M80, so the price is ~$1,500 CDN. This will be in the Epic 80 500 package. The Jamo's are great for 2 channel listening so their not going anywhere.
Tomorrow
Tomorrow
My mains are JBL Studio 312 floorstanders. I've already tested them against 2 grand per pair monitors and preferred the JBL's. From my auditioning, it looks like I must spend a minimum of $4,000 to find a more desirable sound (as in Sonus Faber or Vienna Acoustics).
jlcct
jlcct
I currently run M80's for the front. They are fairly new and I have barely gotten to use them. I am in the process of moving so once I've nailed down the rest of the living situation I will decide what room to put them in and what rooms need's what for speakers. I know I'm keeping them but my decision for more speakers will depend strictly on the environmental variables.
Ryan8886
Tom Andry said:
Rives is giving away three (3) Rives Audio Test CD 2 this month in our dedicated forum contest.
To be eligible to win, you must: 1) Be a registered Audioholics forum member, 2) Have USA or Canadian Residence 3) Answer the questions in this contest thread:
Note this contest ends on January 31st 2007. Winners will be drawn shortly thereafter.
Have fun and good luck!
I have Athena AS-F2.2 floorstanders. These were a recent upgrade, so i can't see anything in the near future. Were I to upgrade in the future for two-channel listening, I probably would not go much above $800 a pair, simply due to budget and space considerations.
supervij
supervij
My mains are monitors, and to get acceptable quality, I'd guess I'd have to spend around a thousand (American) bucks were I to upgrade. (Although that price includes the haggling!)
cheers,
supervij
dpnaugle
dpnaugle
Main: Paradigm Studio 60 v.I would expect to spend $1799 +tax on new mains.
DN
mjhamre
I have Ascend monitors right now, thinking of putting a front projector 7.1 system later in the year, hoping to keep the speaker part in the 5K range for all (including sub) but if I listen and it is 2K so much the better...
--Matt
Status
