I trust you are correct and assume he did, but you included the lower models:
So, for me, if questioning Yamaha's rationale, we should not be asking about the 2 Vrms value but the
1.2 1.4* Vrms that Gene suggests as the limit on the A860! 2 Vrms is not that bad!
I think this also depends on the amp's capability, but ...
Yeah, 2 Vrms is not terrible, 1.4 Vrms is! That is my point! Yamaha should address the 1.4 Vrms which reflects a serious lapse of performance (not the 2.0 which is a marginal lapse of performance)!
I am not willing to give Yamaha a pass on the A860 just because it is a lower level AVR at $900!
* I remembered it as 1.2 Vrms, but went back to Gene's review to double check. 1.6 Vrms had excessive FFT distortion and 1.0 Vrms was clean. 1.4 Vrms is the value Gene seems to suggest as an effective max. Either way, it is poor performance (and decidedly below the capability of the competitors).
The Yamaha AVENTAGE RX-A860 7.2CH Atmos/DTS:X AV receiver is packed with excellent networking features but it does fall short on power delivery making our recommendation conditional based on usage.
www.audioholics.com
