How about forget what I said, but take a look of what manufactures said about power requirement, handling etc.etc., keep in mind this is one area they don't typically exaggerate their rating because of warranty concerns. If you have to time to read them all, you will conclude as I have, that it really depends, so imo if we will safe to not make general blanket statements.
Enjoy!
Dali:
How power handling affects your loudspeakers (dali-speakers.com)
The power handling of a loudspeaker is
very much dependent on the type of music reproduced. Since a music signal simultaneously consists of a broad range of frequencies, it is not possible to define maximum power handling in meaningful terms.
In the real world, large amounts of clean, un-distorted power from a big amplifier is better than the distorted output of a small amplifier pushed beyond its limits.
KEF
Recommended Amplifier Power (kef.com)
Rule of Thumb:
In the real-world, it’s best to ignore the low-end spec. That’s shown to show the minimum amount of power needed to move the voice coils in any appreciable manner.
A good match is an amplifier capable of producing
between 60% and 110% of the recommended maximum.
For example,
the R5 shows a Recommended Amplifier Power of 15 to 200 WPC. A good match for this speaker would be an amplifier that produces between 120 Watts per Channel ((200x.6)*100) and 220 WPC ((200x1.1)*100).
In terms of performance and damage potential, an amp rated lower than 60% of maximum poses far more danger to the loudspeaker than an amp rated above the maximum.
Paradigm:
What amplifier would you recommend for my Paradigm speakers? : Paradigm Support
What amplifier would you recommend for my Paradigm speakers? Print
Modified on: Thu, 6 Sep, 2018 at 3:50 PM
For the best pairing we recommend using Anthem amplifiers.
Amplifier Distortion — The #1 Culprit! When choosing an amplifier or any similarly high-quality amplification, always select an amplifier with a power rating greater than that of the speaker. Using a 100 watt per channel amplifier on a 50 watt speaker allows the amplifier adequate headroom in order to provide a distortion free signal. Conversely, using a 40 watt per channel amplifier on a 50 watt speaker limits the amplifier’s headroom. This causes the amplifier to enter its distortion level much sooner, potentially damaging the speaker.
Klipsch:
Choosing the Right Receiver/Amplifier – Klipsch
Follow
To give you the best balance of power and performance, select an amplifier or receiver that delivers continuous watts (many times also referred to as “RMS”) in accordance with the speaker’s continuous power handling rating.
For example, a Klipsch RP-8000F is a floorstanding speaker with a nominal impedance of 8 Ohms, rated at 150 Watts continuously. So, any receiver or amplifier that delivers right around 150W per channel at 8 Ohms with full frequency bandwidth (20Hz - 20,000Hz) would be a good match.
NOTE: To ensure you do not damage your speakers, Klipsch recommends the AV receiver or amplifier you choose is no less than 80% of the recommended continuous power handling, and no more than double the continuous power handling. For example, the RP-8000F requires an AV receiver with a bare minimum of 120W per channel (8 ohms), and no more than 300W per channel (8 ohms).
I can keep searching for more, I bet you will see the very similar kind of messages from manufacturers, and finally if all fails try Audioholic.com:
The Truth About Matching Amplifier Power to Loudspeakers | Audioholics
May also be interesting see the spectrums of musical instruments:
The Frequencies of Music - PSB Speakers
